How do you test Hydraulic pump???? Ford 1910
/ How do you test Hydraulic pump???? Ford 1910 #1
Pops1910
Ford 1910 4x4
Hi All, New to Forum.........Been having hydraulic lift problems on '83 Ford 1910 4x4 Tractor and wondering if anyone knew of sure way to test Hydraulic pump and pressures. Don't know what else to check. Lift arms will go up if no implements are connected and then only at about 1500rpm. I can hold lift arms down with body weight as position control is raised. Replaced piston ring seal, all o-rings, cleaned relief valve, poppet valve,safety valve, etc.......Changed fluid, filter.........I'm guessing hydraulic pump next???????????? any help would be appreciated !!!
/ How do you test Hydraulic pump???? Ford 1910 #2
Kubota Flow/Load Meter Test - Tractor Videos - Kubota, John Deere, New Holland and More
Best way is to test flow directly at the output of the pump with a flow meter/test guage w/load valve........
It'll show in real time what flow/pressure is at different rpm's and allow you to induce a simulated load, you'll be able to at least rule out pump troubles PDQ.....if the pumps good then work downstream......
Do not take pump apart to look for wear unless you've tested it first and it failed......some guys take a good pump apart and add to the problems.....some guys take a bad pump apart and think it looks good......Don't go there.....
Great video, is it possible to make your own test rig like this??? That looked like a GPM meter and pressure guage with on/off valve
/ How do you test Hydraulic pump???? Ford 1910 #4
Best to use a relief valve instead of on/off valve in case of "Deadheading"....there is a way to use a 5 gal bucket marked off in gals.....testing with a stopwatch to calculate GPM's at different pressures....
Be carefull and use someone else for safety to man the key switch......
/ How do you test Hydraulic pump???? Ford 1910 #5
Yep, that's what it is......
The Ford 1910 has a combination pressure relief valve/ diverter valve for aux equipment manifold midway downstream from pump. The only other thing between this and the pump is a power steering manifold block, I should be able to tie into the aux, connection there to test pressure and flow by diverting the hydraulics to the aux port. I'm thinking that the pressure relief valve should still be in line with this. I'm thinking I have a presure problem for the weak lift of the 3 point hitch arms. It shouldn't take that much flow to push the piston for the lift arms. I've changed all th orings and piston seal for the lift arms, don't seem to be getting enough pressure to lift anything say over 200lbs. Book says lift arms should be able to lift 3000lbs +. What do you think??
/ How do you test Hydraulic pump???? Ford 1910 #7
as long as the flow goes right to the flow/meter you'll be able to properly test the pump......to test pump only you need only to direct flow back to tank.....
putting the flow/meter inline the existing path will allow you to test downstream components while running 3ph or others.....
Thanks for the info, I'll see what I came come up with here in the next few days. I'll see about getting a pressure guage at least and see if I can guesstimate flow per bucket and stopwatch..........Anyway to check if I'm getting flow&. pressure at the lift? It will lift the arms with no load. I even took the position control rod off the arms that works the internal control valves and that didn't help. I was thinking that the rod was maladjusted causing the fluid to dump back into the sump before the arms lifted to full height, but that wasn't the case. Even with no load on the arms when they did raise to full height with the control rod off, it should have built up pressure to operate the relief valve but that didn't happen neither. That's why I'm assuming the pump output.
/ How do you test Hydraulic pump???? Ford 1910 #9
sounds like you have a pump problem. The 1910 i believe is made in Japan.i worked on a ford 1920 , it had the same problem and the pump was bad. dont buy from ford i know a guy who can do better on prices
/ How do you test Hydraulic pump???? Ford 1910 #10
There should be a port somewhere that allows you to hook a test gauge, you may have to rig a connector.
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
15200 (A56857)
15200 (A56857)
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
20704 (A55853)
20704 (A55853)
TEST YOUR BID BUTTON! (A62130)
TEST YOUR BID...
CFG Industrail MX15RX (A53317)
CFG Industrail...
