What is this?
   / What is this? #1
handirifle
Central Coast of CA
Massey Ferguson 1010
   / What is this? #4
a cultivator for hilling vegetables :licking:
   / What is this? #5
   / What is this?
Thanks, that site says 3-4" deep with a 3ft one. That's behind my Massive :) ferguson 16hp MF1010. Based on the pic I'd guess it's about 3ft wide. soil, during spring is soft. Almost zero clay here. Is that deep enough to be useful, or should I just use a tiller and forget it?
   / What is this? #7
Useful for what purpose?
Steve
   / What is this? #8
I don't think the sweeps will replace a tiller to work up ground in the spring. Usually used to sweep through worked-up and planted ground to kill weeds and as mentioned, hill up around plants.
   / What is this? #9
Most likely you would use this after the ground has been tilled....so sounds like a perfect implement for your tractor. However if you are thinking you are going to bust sod with this....I would pass.
   / What is this?
Oh ok, so it's to mound it like corn rows? That type of thing? Using it would be for just a small 1/4 acre or so family garden.
2000 Genie Man Lift (A50322)
2000 Genie Man...
2025 LandHonor PF-11-3500G 4,000lbs 42in Pallet Fork Skid Steer Attachment (A49462)
2025 LandHonor...
2025 LandHonor PHA-16-2C Hydraulic 3 Point Hitch Adapter Skid Steer Attachment (A49462)
2025 LandHonor...
1043 (A50459)
1043 (A50459)
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
Quick Attach Pallet Forks (A47384)
Quick Attach...
