John deere loader specs.
/ John deere loader specs. #1
kuboman
Canada
B3200, L5740,
Does anyone know where you can get the specs for JD loaders. I can't seem to find any useful lifting specs. Maybe I am just blind!:confused2:
/ John deere loader specs. #4
I don't know if it is just me, but I havent been able to access deere's loader specs for bout 6 months now. Something up with their webpage maybe???
But it used to be you click the tractor model on the left, under that click attachments, then scroll down to the loader. Once you click on it, it has a link to view specifications. Once you click on that, it used to display the loader specs. Now it just displays a blank page and at the top of the colum on the left in red letters it says "deere model not found"
John Deere products for homeowners: Features for Attachment 300X Loader
This is the link to the 300x loader on a 3520. But if you click view specs, it says not found.
What model are you wanting to know BTW
/ John deere loader specs. #5
I suspect that the manufacturers are leary of lawsuits is atleast half of the problem. Particularly with residential/consumer equipment. What you can lift on level ground would be far greater than what you can do on a side slope.
When you look at the Construction specs for Deere, Cat and others it is listed.
"What model are you wanting to know BTW"
I wanted to compare a whole raft of loaders with deere and kubota. Not sure how to research this one if the info is not available.
/ John deere loader specs. #7
There are specs for the 520 and 540 loader. On some of the newer loaders 300CX have to dig a bit "Transporting a Round Bale". Granted this is not the level of detail I am guessing you are looking for, but it is something.
I will give that a try. Thanks
/ John deere loader specs. #9
There are specs for the 300x and 400x are on TBN somewhere.... use the search function and your should find it.
-Jer.
/ John deere loader specs. #10
Instead of a "whole raft", list the JD loaders you want specs on someone may post them. Give us a chance to help.
The manual for my 640 lists them, I also have old brochures with many models and their specs.
Well I guess I am looking for the 300 series. Not sure how many models there are but I would like to compare them to the Kubota loaders that go on their 30-40hp tractors.:)
/ John deere loader specs. #14
I still cant believe JD makes it that difficult to find the specs for their loaders.:confused:
It can't be good for business. I would think for their "tech savy" guys that do the webpage for them it would be a simple fix.
I don't believe it has anything to do at all with lawsuits and whatnot. ALL OTHER manufacturs make their specs very easy to find. With the exception of bobcat. They have a more difficult site to navigate through.
But MFG's like kubota, kioti, mahindra, new holland, etc ALL have very easy sites that are easy for a potential buyer to navigate through and compare specs.
/ John deere loader specs. #15
Maybe it has to do with the changeover in the tractor lines that is going on right now?? JD's site has never been super intuitive (esp. for such a hge company), so many they just took them off for now??
-Jer.
/ John deere loader specs. #16
This list is about 4 years old, maybe it's what your looking for.
Thank you everyone. Very informative.:thumbsup:
/ John deere loader specs. #18
Problem is that both specs only go up to the 400 series loader. Nothing for the larger 500+. But what I was told when I ordered by tractor that my 512 loader will lift at least 2000# in the bucket. So far that has held true.
/ John deere loader specs. #19
From the JD brochure NEW 5 SERIES UTILITY TRACTORS, page 17;
John Deere Loaders built to fit:
512NSL
lift at max ht 2453 lbs*
breakout force 4775 lbs*
max lift ht 114"
clearance bucket dumped 85"
reach at max ht 26"
digging depth 3"
dump angle 57 degrees
rollback angle 23 degrees
* measured at pivot
/ John deere loader specs. #20
Here is the specs, attachments and pictures for the following 3 JD loaders 512, 522 and 542
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2015 Ford Mustang Convertible Coupe (A64557)
2015 Ford Mustang...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2022 EZ-GO ELITE...
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
