Obed
Elite Member
ruralruss said:... it is just a standard 2 piece water softener with out the salt tank and instead of resin pellets in the cylinder he put in around 8 layers of specific shaped, decreasing size aggregate.
Thanks for the info Russ!
Smoke Detectors
Also, is there a way we can prevent all 7 detectors from alarming? I' like only the alarm that senses a problem to sound the alarm so that we can quickly find the problem without having to wander all over the house.
Thanks in advance for your comments,
Obed
We have baseboard stops where they are possible.dstig1 said:Best door stops are not on the hinges at all, IMHO. The type that you screw into the baseboard or floor are much sturdier and last a lot longer. I only use hinge mounted stops when there is no other choice, usually due to there being no good place to put a baseboard style stop or a floor mounted stop would be in the way.
One man's opinion...
The doors got hung. I don't think I like these door hinge stops. I've always seen stops that have 2 stoppers. These things look to me like they will try to bend then hinges if then doors is opened too forcefully. Does anyone have anyone experience with stops like these? Are they ok?
Thanks,
Obed
Thanks,
Obed
How hard are you folks on your doors ?
Some folks are gentle enough that they could get by without any kind of stop. Others could have a freakin' rail road tie laying behind the door and still manage to bust up whatever is back there.
I am on the gentle side (patting self on back). My wife is rough on stuff. She could tear up a steel ball with a rubber mallet.
