Bush Hogging rates for 2010
   / Bush Hogging rates for 2010 #1
fieldman12
Gold Member
OHIO
2001 New Holland TN70,2003 John Deere 250 Series II skidsteer,1987 John Deere 2155,2013 John Deere 5055E MFWD,2007 Duramax 4x4 truck, 1973 MF 165,Artic Cat 550 Cougar sled
In your areas have prices on Bush Hogging dropped? Around here people want it done but they wait to call until it is 4' tall or more and in some cases has set for years and small saplings are growing on it. I have around a 60hp tractor and 6' Bush Hog. People in the area could make better money doing this ten year ago than they are today around here. I know charging by the hour is best. What are you guys charging for a field that is very tall per hour? How much can you expect to cut acre wise per hour in a tall field over 4' but other wise no obstacles to worry about? I'm figuring about a half to three quarters an acre an hour. On stuff no tall than 18" about 1.5 acres per hour.
   / Bush Hogging rates for 2010 #2
I have a 10ft rotary mower-120hp tractor and I deal mainly with once a year maintance mowings on large plots.
I charge $65/ hr for any small stuff. For small trees and anywhere that has a lot of nails or other sharp objects I get $85/hr. One flat tire costs a min. of $150 for a tube replacement, up to $1000 if the tires gets a bad side wall cut.
Working for the general public is tuff. They usually call when its way past due and only cutting a couple ac at a time. If you can find some work thats once a year / every year would be your best bet.:thumbsup:
   / Bush Hogging rates for 2010 #3
I have 7 AC of which i'm guessing 4.5 to 5 is being cut. I paid $150 a few months ago.
   / Bush Hogging rates for 2010 #4
i got a 7ft bush hog and usually charge $45 an hour. Average an acre per hour, i don't advertise. If i have small trees, might add some $$$'s.
   / Bush Hogging rates for 2010 #5
I mow with a heavy duty 6' Woods that I have mowed commercially with for years (like 15) and a 45 hp Kubota. I figure in good going I can do 3+ acres an hour and charge $100 per hour plus a delivery fee. If the going is rough I have to downshift which lowers my coverage rate but of course takes longer so I make more.
In the worst going I still manage to do 2 acres an hour, it's not about speed, it's about efficiency. No backing up and keep moving in a fluid motion. It's amazing how much time you can knock off a field if you lay it out and plan your moves so you don't double back or have to use reverse.
   / Bush Hogging rates for 2010 #6
I know the rate you can charge will vary a lot depending on how close you are to a large city, where there are not many custom cutters available for service. In the country, every farmer has a brush hog and the guys that don't have cutters, have friends that do. I would venture to guess that rates in Ca, Ma, NY,Wa, Or, Etc. probably are triple what they are here in rural Ky. Ken Sweet
   / Bush Hogging rates for 2010 #7
Friends of mine own a 5-acre grass field, no trees at all, 3.5'-4' high grass, & paid a relative $200 to mow it.
The friends thought they paid too much, but I bet their relative was sorry he agreed to do it for $200.
   / Bush Hogging rates for 2010 #8
Actually, everyone and their brother around here has a tractor and will work for bird feed. I carry full insurance and have been doing it for so long that if they want it done clean and neat they call me, they want it done cheap and want to look for someone new each year they call someone else.
I can't tell you the number of jobs I have walked away from because they refused to pay my price, then they call me back the following year and ask if I will do it any cheaper 'cause the guy they hired last year is broken down or did a crappy job. I tell them the price, most of the time they hire me for what I quote after they have learned their lesson.
The problem here is the rocks. Most 4' mower get destroyed within a year or so. You really need a heavy duty mower to handle the terrain here.
I have hobbies, I don't need to mow for free.
   / Bush Hogging rates for 2010 #9
My standard rate is $100 for the first acre and $65 for every additional acre if I am cutting a small (1-5 acre) spot. Anything larger, and I try to get $65/acre, but I have gone as low as $40 per acre. A lot has to do with height and thickness of grass, distance from my home, obstacles, etc. I'm not interested if someone doesn't want to pay me for my time. :thumbsup:
   / Bush Hogging rates for 2010 #10
I have a 30hp tractor and 5' brush hog. It takes about an hour an acre on perfect fied. when the grass is tall or the terrain is lumpy i just slow it down so me and the machine don't take to much of a beating. I charge $30 per hour from the time i leave my house to the time i get home. I do tell them a time estimate but explain that conditions determine the outcome. If i quote them $300, I stop at 10 hours and ask if they want me to keep going, From that point we can usally determine how much lomger it will take. When I talk to people on the phone they tell me it's a golf course, when I get there it looks like a war zone with the holes, rocks and metal fencing laying all over the place. I say charge by the hour and take your time, these machines are expensive.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
