Boy this thread really took off. I had quite a few pages to read to get caught back up this morning.
Duffster: IMO your ramblings are meaningless unless you can give a little more verifiable detail as to which tractor you have etc. Some larger 100+ HP farm tractors may indeed be able to not overload the front axle without ballast. But we are talking CUT's and SCUT's here and there is a big difference. SCUT's are built light so they can mow and tread lightly across lawns. Working a FEL to the max DOES require rear ballast not only for saftey but for the longetivity of the front axle.
I did dig out my L3400 manual and I was dissappointed to find that there wasnt a rating for the front axle anywhere. It is not listed online either. I think JD is the only one that lists that spec online. So who knows if its 2500lbs or 6000lbs???? But 2600lb tractor + 900lb FEL + 260lb bucket + 500lb fluid + 300 lb blade = 4560lb tractor weight. And at that weight, I can still lift the rears. That means I have all 4560lb on just the front axle PLUS whatever weight is in the bucket ~1000lbs:confused2: I try not to do this because I cant help but think that it cant be too good. Plus the 7x16 AGs up front say Max load 1100lbs:confused2:
But What I did find in my manual may be of interest to those who disagree with putting weight on the 3PH. This is word for word
"For tractor stability and operators saftey, rear ballast should be added to the rear of the tractor in the form of 3-piont counter weight and rear ballast. The amount of rear ballast will depend on the application.
Meaningless? Really? Who are you to make this assertion?
If you must know I am referring to a MF 399.
I don't disagree with using counterweight, just don't agree with the statement that you have to use counterweight. The excerpt form your manual seems to agree with me.
With the figures you have given is it even possible to counterweight your tractor enough to keep the front axle under the (tire) rating?
