Chain top link
/ Chain top link #1
TGF
Gold Member
Blair, NE
3038E
Does anyone make pre-fab chain top links, or is it a make your own kinda deal with a very short logging type chain.
/ Chain top link #2
make your own.... I did....use it with my box blade, really helps keep things smooth thru the ups and downs.
/ Chain top link #3
You will find lots of good ways to make one on here.
Here is the way I did it. Used a logging choker and cable slider on a 3'
piece of chain
/ Chain top link #5
John or Gordon,
Please enlighten me regarding chain top links, their purpose and how to use them.
I have a Road Boss grader similar to Gordon's and that chain setup looks intriguing.
/ Chain top link #6
I have a hydraulic top link. When used as a flexible top link, I shorten it and add a link from a ship's anchor chain... about 10 inches long. A segment of heavy chain between end of hydraulic top link and attachment point of box blade could be used in place of the ship anchor link, I just used what I had available.
When using the box blade on uneven ground with the fixed top link, I found I had to constantly raise and lower the blade and adjust the angle of attack to keep the blade on the ground and try to level the road out. This is because a compact tractor has a rather short wheel base. When the front wheels rise up on a bump, the box blade is forced into the ground by the fixed top link, causing a dip. When the front wheels drop down, the rear blade rises and drops its load of dirt, causing a bump.
If, however, there is flex in the top link, within reason it will take up slack or gain more slack in the above conditions, maintaining ground contact resulting in fewer passes and smoother road.
In operation, I lower the box blade to the ground, lengthen the hydraulic top link+chain such that there is some slack. I raise the lower two points of the 3ph so that the angle of attack of the actual rear blade is nearly flat, maybe just slightly digging in.
Weight of box blade plus added weights is about 1000 lbs.
I have my own hydraulic trailer and live near limestone rock quarries. Thus, acquire loads of road base for my ranch roads. Try as i might, I can't always evenly spread the new material...sometimes I have one foot bumps to smooth out. This rig helps me.
I am sure that there are many approaches to doing this task...this is how I do it. Suggest you create your own flexible link and give it a try...not terribly expensive.:thumbsup:
/ Chain top link #7
Chain top links are handy but be CAREFUL where you use then. If you need to hold the impliment so it will not roll forward (ie flail mower ) dont try it.
When I begin grading a hard packed road, especially one that may have rocks embeded,
I use a standard top link and adjust it for the conditions and cut I want to make. Doing this requires the normal readjustments in the dips and crowns. Once I have the surface
losened up and the big rocks out I put on the chain top link to let the grader follow the
road contour. This seems to give me the best job. If I had a hydraulic top link I probably
wouldnt need the chain.
If I start out with the chain and the cutting edge hooks on a solid rock the back end of
the grader jumps up (sometimes vilently) and pivots forward on the front skids until
the rock is cleared or pops out of the road bed. There is no top link to stop this. While
it has not happened to me the whole thing could possibly flip forward into the back of
the tractor because there is no top link to hold it back.
There are lots of discussions and opinions and pros and cons on here if you do a search.
/ Chain top link #8
This sounds like a "lead-in" for the new "hydraulink". :laughing::laughing:......which, in all seriousness, may be a good product for your application.
/ Chain top link #9
piece of chain
Where did you buy theh logging choker and cable slider at? I like the looks of that top link because it is real easy to change the length when switching implements.
/ Chain top link #10
By not using a solid toplink, there is a possibility the implement could wind up in your back or at the best on the backside of your tractor. If a 3 point implement hits something solid in the front, you could have a problem. Ken Sweet
/ Chain top link #11
I just don't buy that argument that the implement can end up on your back. It is hypothetical at best and hype at worst. Sorry, but it is a fear perpetuated that if true, even a solid top link wouldn't prevent (break something first).
Sorry to disagree with the experts.
As always, I could be wrong too. Just in many hours for many a year, never have had a 3pt attachment flip forward as described.
/ Chain top link #12
I can only speak from first hand experience or what customers have reported to me during my 33 years of machinery business. I have personally had a solid toplink save my life on more than 1 occasion. Usually while brush hogging, going steep upgrade and the tractor front end would come a foot or more off the ground and stop when the toplink caught and stopped the potential flipback of the tractor. No chains for me! Solid or Hydraulic. Ken Sweet
/ Chain top link #13
I'm with Ken Sweet on this one...that top link can save your butt.
It can also save your tractor's PTO by preventing the implement's drive shaft collapsing too much when crossing an abrupt change in topography.
Nothing hypothetical about that...
/ Chain top link #14
I'm with Beenthere on this, fear perpetuated hype.
Kinda like the pto screw splitter hype.
/ Chain top link #15
No disrespect intended but I think that anyone who thinks that a top link has saved them from going over backwards is probably dreaming. When you start to come up the lift arms have come all the way up before the impliment and top link can catch you. At that point you are well on your way to going over. If you have enough momentum to get that high the top link will just fold. IMHO.
/ Chain top link #16
If that is the case, Why would I have bent a top link in the process of brushhogging up a steep incline? Ken Sweet
/ Chain top link #17
Yeah hog back can and will come up,I use just a length of heavier type chan with a couple of connectors on my hog,had back come up,maybe a foot or so a couple of times and bang back down,will get your attention.
I just cut grass and it came up just by front edge hitting against uneven ground,[had front to low],now I wouldn't use a chain top link if I was actually cutting brush or had stumps sticking up here and there,but if you got fairly even ground and just grass,it will let you get a more uniform cut with out rear wheel coming off ground.
Would think the worst that could happen if you was unlucky or careless while using a chain,would be damage your pto,if it came way up and your telascopeing drive shaft butted up,always best to have a good bit of play,both ways when hog is level.
I cut about 6inches high or so,and know my ground,so chances are not great of front catching,but yeah,its something anyone doing it should know could happen.
I wouldn't think about using a chain for anything else,[blade,tiller,etc].
/ Chain top link #18
You bent it. But did it save you from going over? ?
We will never know and the arguement will go on forever.
Discussions like this can be good because they makes people think .
/ Chain top link #19
piece of chain
Hello Gordon,
Can you tell me the manufacturer and model of the logging choker and cable slider and what size chain you are using? I have an upcoming need for that setup. Thanks, Jerry.
/ Chain top link #20
It is a 5/16" chain with a standard type choker hook for 5/16" chain. I picked one with a small opening so it could not come off of the 3/4" top pin.
I remember when I got the slider I had to check and make sure the 3/4"
top pin on a CAT 1 3pt hitch would fit through OK. A slider for a 5/16" or 3/8" cable would probably be to small. Sorry I dont know the mfgr or number.
We have several equipment stores around here that have all kinds of stuff like this. I just picked up what I needed and there is no marking on them.
They were made in Canada because they have a CS stamp. Not much help.
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
Altec Digger Derrick Hydraulic Boom (A61573)
Altec Digger...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64281)
KNOW BEFORE YOU...
2015 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2015 KOMATSU...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
John Deere 608C (A64119)
John Deere 608C...
