two machine solution?
/ two machine solution? #1
Magilla1
hills of Virginia
Seems like there's been a debate on this forum about the two machine solution. That is, a lot of us are country folks who have a decent little patch of land, maybe 8-30 acres, with a couple or three acres to mow, long gravel driveways to maintain, some snow to push in winter, various dirt, landscaping and big garden work, messing around in the woods, etc. Some guys are interested in one tractor to do it all. That's why JD sells so many of the 2000 series with a MMM and FEL as the big attachments. Other guys take the view that it's better to have two machines; a pure mower and then a tractor for everything else. I'm trying to get opinions/experiences with both, because I'm right at that decision point right now.
I think the do-it-all tractor folks would say:
1. Maintaining two machines is a pain.
2. Buying two machines, all other things being equal, is more expensive than one machine. Plus buying two machines requires you to store two machines, so you've got to have quite a bit of barn/shed space available.
3. The MMMs on the tractors mow pretty nicely, so you don't need a pure mower.
4. Unless you buy an x700 series mower, which is almost as expensive as a CUT anyway, the two machine solution means your mower is going to be a belt-driven machine, and there's just no way it'll hold up for more than a decade, while a well-maintained CUT should still have a lot of life and value a decade down the road.
I think the two-machine solution folks would say:
1. Maintaining two machines isn't such a big deal, really.
2. A good, dedicated mower (like an x300, say) mows better than a MMM on a 2000 series or 3000 series. Better cut, more manueverable and less tippy on hills.
3. Having a dedicated mower means you're not switching out the MMM (and FEL or other attachment) as you go back and forth between mowing and other work.
4. A MMM costs around $2500-$3000, and a good x300 or x500 series costs $4000-$6000, so the savings of one machine is there but not comparatively huge.
What do y'all think? Anyone out there start with the all-in-one tractor and then decide to go with the two machine solution? Anyone out there start with the two machine solution and then regret it? Anyone disagree with the considerations I suggest above or have different ones to add?
/ two machine solution? #2
I have 6 rough, hilly acres, 2 of which are lawn and 4 are pasture. When I moved here, all I had was an old JD 185 lawn tractor. I knew I needed some type of compact tractor to handle the chores (finish mowing, rough cutting, snow removal, gravel drive maintenance, etc.).
I decided to go with a JD2520, knowing that I'd still need something smaller to cut in around the edges and get in the tight spots. A dedicated mower sounds good, but the property is so rough, anything smaller than a 2520 would beat me to death.
My problem is, I need a better trimming tractor. I need something that is the size of the 185, 42 inch mower deck, 4 wheel drive, 4 wheel steer and only costs a few thousand. Unfortunately, I don't think such a machine exists, except maybe a used Simplicity.
All the above notwithstanding, I still believe I have the best solution for my needs, i.e., a compact tractor with a lawn tractor to cut in the edges. It's just too rough and steep to use a lawn tractor (or ZTR) for the whole thing, but I can't get in the tight spots with the 2520.
/ two machine solution? #3
Not to sound arrogant but I am not confused about any of this stuff. I am interested in easy hookup yet wan't it to perform as a specialized tool. I have a small tlb for digging and loader work. Two tractors for 3pt work and a lawn mower for mowing the lawn.:D
I don't use a lawn mower to till or dig out stumps, a mower needs to be light, agile, and have a very small turning radius. I don't want a fel on my tractor either but I do wan't it large enough to get some work done, something a lawn mower cross has trouble with. While I have a 3 pt hitch and top n tilt for my tlb I prefer to leave the hoe in place unless I really need three tractors at one time (isn't likely). For digging I looked around and used lots of different machines before deciding on the Deere 110. Initially I wasn't impressed with the 110tlb, I really thought a separate mini excavator and compact wheel loader was the better route. Also considered a Terex 760B full sized cab with extendahoe because the price was cheap. Transportation was the problem with these other combinations though, I finally decided I could do at least 90% of the jobs with the smaller 110tlb in one trip behind a service truck and this just made more sense.
After many years of using different equipment I have narrowed it down to a good lawn mower and am planning on purchaseing a Deere X749 for this, keeping the 4520 cab ehydro for 90% of the tractor work. Keeping the 110tlb for 90% of the backhoe work, I can always hire or rent a larger or smaller unit when needed. Lastly if I really need a heavy tractor for tillage then I will consider a Deere 100+ hp tractor at that time.
In my opinion, after a long winded post, "Eight in one tools suck big time."
/ two machine solution? #4
After many years of using different equipment I have narrowed it down to a good lawn mower and am planning on purchaseing a Deere X749 for this...
Let me know how you like the X749 as that is my dream mower right now. I really want the AWS, shaft drive, power steering, power deck lift, etc. I have 30 trees to mow around plus a number of man-made obstacles that the X749 would be nice to have, even on the small lot we live on.
Your quote says it best!
Back to the OP, before all the trees got planted and the ground was inhabited by tumbleweeds, the 5' Bush Hog on my 4200 wasn't that difficult to use and maneuver. Now the cutter isn't used often; but I won't get rid of it as its paid for. Removing/installing the loader on my 4200 isn't difficult; but I sure don't want to deal with the hassles of doing the same with a MMM for my 4200.
Now the L-130 does the mowing chores of native grasses and non-woody weeds; but it's tiring without power steering.
/ two machine solution? #5
Quick question Runner...how do you like your mirror setup for your loader, and I'm assuming you are only using for non-bucket type of attachments? Do you have much trouble with vibration blurring the image?
We now return you to our regularly scheduled thread.
/ two machine solution? #6
You've hit most of the major areas of discussion regarding the pros and cons of owning multiple platforms. One point that I don't necessarily agree with - that a belt driven mowing tractor will only last a decade. I'd argue that with appropriate care and upkeep; it's not unreasonable to expect another 5-10 years beyond that - especially if you work up to the middle of the series - X360, say.
One further comment that I can offer - are you the only person in your family that will be operating any of the equipment? One major advantage that saves me considerable time is that my wife and youngest son can work one or both machines and allow me to work on something else. More chores taken care of at the same time..
That said, I'm a real believer in the 2-tractor family. I started out with a JD 970 TLB (after renting various machines over several years) and found I did not like the chore of dropping the hoe to attach a mower.
Plus, the tractor was just a "skooch" too big to mow the edges and some corners and around some of the awkward spots around buildings and fences. So, that all had to be done with a push mower.. Which I liked even less than dropping and reattaching the backhoe.
After using the 970 for about 4 years, I decided I wanted a bigger, more capable TLB. After 4-6 months of research and test driving a half dozen different models and brands; I settled on a JD 110 TLB. A few months after buying the 110 - I bought a new X300R.
I no longer hassle with trying to mow with the 110 and I don't have to clean up the mowed areas with a push mower, either. :thumbsup:
However, I'm finding that I need another tractor for heavier duty PTO and 3pt work more often than before --- so, I'm now looking for another tractor... Therefore, the question now is: 2 machine family or three?? More and more looking like 3.
Best of luck with your decision.
AKfish
/ two machine solution? #7
mjncad,
The mirrors work fine, once you get them aimed. They are both on the small side, so they have to be aimed (at the trailer hitch) perfectly. Surprisingly, vibration is not a problem at all.
Back on topic, I forgot to mention I also have the desire for power steering on the trimming tractor.
A tall order indeed.
/ two machine solution? #8
I started out with one tractor and used to back drag the lawn when the grass got too high. Graduated to lawnmowers in various colors and types and ended up with a zero turn mower. I now mow more and do the neighbors too. Got a second tractor, B7800HST, and now use that more than my L4350, go figure. Finances have a lot to do with decisions too. All I can say is if you are willing to change over one machine to do all the things you want, then go for it. I am not.
I had a shopsmith in my early twenties and learned what a pita it was to switch over every time you wanted to do a different function.
/ two machine solution? #9
Thi biggest advantage I see in (2) machines is tires. With just (1) you are setting yourself up for disappointment with R4 tires which are only real good for industrial applications for which they were designed. They will not give you much better traction than turf tires off the lawn, and will damage a soft lawn almost as bad as R1's. (2) Tractors lets you have the best tire for every job - turfs on the lawn, R1's off. Transmissions can also be optimized for on and off lawn usage, with a hydro being better for lawn mowing, but a gear is better off the lawn, especially for ground engaging work. As far as more maintenance with multiple tractors, not necessarily so. I currently have (2) tractors for on the lawn and (4) for off. Splitting the work up with multiple tractors prevents any one from being overworked and really limits breakdowns compared to what would occur if trying to do everything with one machine. Most maintenence is done according to hours on the machine and if the work volume is the same then so is the maintenance regardless of how many machines you use. Also, multiple tractors reduces or eliminates time changing implements and lets other folks help out getting the work done. Maintenence can usually be done inside when weather is unsuitable for outside work but having multiple tractors ready to go lets you make maximum use of times when weather and field conditions are favorable. I do believe that (6) tractors is a little over the top however and I am currently trying to unload one of my off-lawn models. I have a buyer lined up and as soon as he gathers the cash (he has about 3/4) he is going to come over and pick it up.
/ two machine solution? #10
If I had flatter, smoother property, I'd have a ZTR for mowing, lawn tractor for little jobs, like pulling the sprayer, lawn cart, etc., and the big tractor for heavier jobs.
I've just heard too many horror stories about ZTR's and hills and on rough property, so, stuck with the lawn tractor and compact.....
/ two machine solution? #11
Two machine??
I have 4 now. :) Three 54" decks on AWS JD 425 (for leaf/grass pickup), AWS JD X485 for sprayer and broom work (don't like the 54" deck mowing ability), and now an AWS JD 455 that I like the best of all. They go with a 4x2 Gator and a JD 4300 for loader and "big" tractor work. I should trim back to just two, but can't make up my mind which two to get rid of, at the moment.
I'll second the comment about AWS for getting around on 6 acres of lawn with many trees and hill sides to mow. Just the ticket.
/ two machine solution? #12
Never owned one but a friend of mine had one with all the add ons, worst table saw arrangement I have ever seen.:laughing: My buddy was blown away when he first saw my SCMI 3.2 meter sliding table saw.:thumbsup:
/ two machine solution? #13
Listening to others here helped make up my mind to skip the zero turn mowers, living in the mountains there are too many hills and steep slopes. I know I don't need my 820 much anymore and am looking to do some trading to eliminate the L130 riding mower and selling off the 820. Replaceing these with the X749. That would leave me with a decent progression of JS45 trimming mower with front caster wheels, X749 riding mower, 4520 and 110tlb. I can get most things done with this setup.
/ two machine solution? #14
And if you get the AWS, the JS45 will sit in the shed most all year long (like mine). What little trimming is left, is easily done with a good weed whip on a shoulder harness. :D
/ two machine solution? #15
You might be right about that too.:D One thing I have in the shed that gets very little use is a DR trimmer mower, no one wants to use it, when it is used it isn't as neat as a mowerblade. Thankfully the trimmer mowers are a small investment at any rate.
/ two machine solution? #16
When I was a kid, we had a 5 HP Wheel Horse with a blade on it, and a 8 (replaced later by a 12 )HP Wheel horse with a snow blower on it. Great pair, my older brother blew and I plowed as the tender age of 12. It was a good snow two machine solution :).
20 years ago, when we moved to a 10 acre house, I got a JD318 garden tractor (18 HP Gas). It had a 52" MMM on it. Got the front blade for snow/gravel road maintenance. Also got a cart to help move things around. In 1997 I got the Kubota B21 TLB (21 HP, hydro, MFWD). Life was pretty good. Got a landscape rake and tiller for the B21. So I had the loader, backhoe, tiller and rake, and used the 318 to mow and do snow. For 10 acres, it was the perfect two machine solution :thumbsup:.
2009 got the JD 4520, no loader (since I had one on the B21). At our new house, I was killing the little 318. Original spindle bearings lasted 16 years, 2nd set lasted about 4 years. Bought a new 48" deck for the 318 for about $1K that had been sitting around at the dealers since 1994 and fit the 318. About twice the cost of having the spindles repaired, but I had used the heck out of the original deck over the years. So now it's like a new mower.
So I'm a big fan of a separate machine for close in lawn mowing, with all it's compactness and tight turn radius _and_ a larger tractor for tractor-like implements. If the 318 has a major malfunction, I'll replace it with the x700 series, the big win being the 4WD (the 318 is rear wheel drive only). My three tractor solution is a result of keeping things going over the years, and moving from 10 acres to 54 acres. If my B21 had a major failure, I'd probably get a loader for my 4520 and be back at the two machine solution. If I then needed a backhoe, I'd contract it out.
Also have a push mower, weed whacker, and hand trimmers. And I've occasionally pulled a blade of grass with my fingers :laughing:.
So I'm a big fan of the 2 tractor solution, and you can take your time getting there to spread out the financial hit. For a little more than a MMM cost, you can get into a 300 series lawn mower, and get some good years out of it. If $$s were critical, I'd even take the L130 instead of a MMM on a utility tractor.
Pete
/ two machine solution? #17
My two machine system is the JD 4115 w/72"mmm and JD x300 42"mulch deck.
Dry conditions: x300 for trim/close work. 4115 for speedy finish.
Wet conditions: x300 only. 4115 is too heavy and creates damage while turning for soft conditions.
/ two machine solution? #18
Very simple solution.... buy as many as you can get away with. I have a NH TC 55DA, JD 4110, Bolens HT18, 2 IHC Cubs with mowers and sickle, a AC D-15, and a melroe bobcat. The deere and New holland have loaders while the New holland also has a backhoe. Numerous three point equipment ( rototiller, brush hog, deep tiller, flail mower, pto rock rake, seeder/cultipacker ) to keep them busy. I just decide what color I want to drive. Who needs purpose or justification ? I guess that is why I have a shed full of cars also.
/ two machine solution? #19
I originally started off with an old Allis chalmers lawn tractor that was on its last leg. It always chewed up every mower belt I put on it and the engine ran bad. So my neighbor scrapped it and a few years later I got my L118 Deere to mow the lawn after having to use a push mower for up to 3 hours to cut our lawn. With my L118, i can cut the grass in 1 hour. Next, i got my Yanmar 169D for work in the woods and grading the driveway. A month later, I contacted a guy i had helped build a barn for in the summer and got myself my 9518 simplicity diesel tractor. The simplicity doesnt run but by the end of this summer, it should be back again as I need it for the tractor jobs i am getting. (i.e. i have to cross lawns a lot and r1s arent the nicest to the soft ground) So with the simplicity, i can cross lawns with the r3s and have a deicent tractor for rotortilling, mowing small fields, and grading roads. The best part, if I get one stuck or one breaks, i have a backup machine. The r1s are actually a lot better on our yard as it is hard packed clay. I can drive the yanmar all over the yard and it wont damage it. Due to that, I'v though of getting a finish mower in the next few years as a backup lawn mower. I have to say, my team of 2 (since the simplicity doesnt run yet) is perfect for me.
/ two machine solution? #20
I still have my Unimat SL-1000 model-makers lathe that is similar to the ShopSmith and like the SS, it's a PITA for the same reasons you mention.
2016 FORD F450 CREW CAB SERVICE TRUCK (A69167)
2016 FORD F450...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2013 FORD E-SERIES VAN (INOPERABLE) (A67714)
2013 FORD E-SERIES...
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
2023 Chevrolet Tahoe SUV (A66738)
2023 Chevrolet...
2014 Forest River XLR Thunderbolt 40X12HP 40ft. Tri Axle 5th Wheel Toy Hauler Travel Trailer (A66738)
2014 Forest River...
