Mowing hillside mowing techniques
/ hillside mowing techniques #1
wasabi
Cullowhee Mountain, NC
PT2445 and PT1850
after years of contracting out our field mowing, i'm about to take delivery of a used PT1850 with 90" single-deck, 3-spindle mower to handle the mowing going forward. First task is to tackle recovery mowing of eight or so acres of steep, slightly overgrown meadow. mostly orchard grass cover base in early spring growth is not bad...but there are also numerous brambles, locust saplings, etc to contend with. goal is to restore and maintain meadows, not create fairways. most saplings are less that 3 inch caliper so my thought is to set deck high, go slow and take a couple of passes at it to knock it down and chip it up. would love to hear any suggested strategies, techniques, safety suggestions...etc?
/ hillside mowing techniques #2
Went online and checked out the PT1850. Awesome hill mowing machine for sure. I doubt very few choices better. Sounds like you have a good plan.The locust saplings are going to be rough on the tires but better to get them when they are this small.
/ hillside mowing techniques #3
My experience is with the 1845 and a 72" deck. I wouldn't use it for any thing much more than 1". Other than that you need to do your best to make sure there are no hidden machine or bone breakers--large rocks, steel cable, large pieces of metal, hidden cave entrances, etc. Brambles (and locust thorns) will give you flat tires--you may want to consider a high quality tire sealant before first use.
/ hillside mowing techniques #4
A three inch sapling will sure rattle the dust off a tractor and rotary cutter. Take your time on the saplings. You can tear the mower up if you try cutting some too big. My rule of thumb is if the tree is so large it raises the deck up going over it that tree is too big to mow.
/ hillside mowing techniques #5
I'm sure the 1850 will handle the slope, so that's a wise move. However, if you really have 3" saplings, I think they will destroy your field mower. It's not designed for that.
I would look at buying a chipper and taking the saplings down and chipping them separately. The rough-cut mower will certainly handle brambles and smaller branches, like shoots, but if you really have 3" diameter little trees, you're going to need a real life chipper, in my opinion. You can usually rent one with a 6" capacity for a couple of hundred bucks a day. I'd take them down with a chain saw and then chip them.
-Rob :)
thanks for the responses. prudent move would be, as suggested, to chainsaw and chip the saplings...and we'll likely do just that....problem is there are eight acres of them....oh well, at least it is a one time project
/ hillside mowing techniques #7
Hi Wasabi,
I agree with your plan. Mow what you can and chainsaw what you can not. With a traditional tractor and a heavy duty brush hog with PTO protection, i could chop up anything that the tractor could push over. 3" would be pushing that limit. The mower on the 1850 is not intended to do things like that. It is a different design - it does not have the extremely large heavy blades working in its favor.
Depending upon the number of trees and the weather/regulations where you are, you could pile them for wildlife or burn them.
Ken
Hey Ken,
Thanks for your insights. As the unit I'm getting is fairly new (less than 400 hours) I'm doubly inclined to not beat it up. On your and other's advice I think I'll hire some young muscle to cut and chip the locust whilst I get seat time...
I've been considering buying a chipper...think I'll rent for this project, but it would be handy to have one. I'll cross my fingers that chipping will break up the thorns...otherwise I may go with the burn pile approach
/ hillside mowing techniques #9
Dear Wasabi,
The PT large brush cutter can handle 3" trees- no problem- but see the related warning about flying debris... :)
If you don't have a brush cutter, you might consider getting someone out with a masticator on a skidsteer as a one time removal. (Assuming that there are safe landing zones at the bottom, and a place to start on the top...)
Or borrow a herd of lamas and goats...
All the best,
Peter
/ hillside mowing techniques #10
Woo Hoo. Another slope mower mower.
I am still working on my 40 acres of slope to sever slope. Last week I finally broke my 30 degree mowing and made it to 45. It was just a 10 foot berm with a road at the bottom but man I was really, really puckered up.
As I do 40 acres here is my ton of notes.
The blades on the PT suck. I hope you ordered spares. What I have done is left the 3/8 steel blades off, and went and had made 1/2" hardened steel blades. I am not sure if I am adding wear to the bearings and the machine is swinging a lot more weight, and balance is much more critical. These blades WILL break off, and go by by. Get spares for whatever you do. change the blade bolts to grade 8. Remove the "cap bolts" These are 2 additional bolts but underneath the mower. PT knows that the machine breaks bolts so they give you extra holes so you can keep working. I put in hex plugs into those holes (I can get you a picture if you need). Spray paint your blades a bright color, it helps when they break off. (only a little paint will remain, but anything helps). carry a hammer. the blades get stuck under the hubs. Absolutely remove the spare bolts from the center hub. It is the one that is direct drive and the most prone to breaking bolts.
Remember that the 1850 is 65 HP and 4000lbs. When you hit something imovable(for me it is hidden tree stumps) you will know it. This week I replaced the upper bar with thicker square tubing as I had bent mine up pretty bad.
The mower is low maintenance. On mine there is 3 lube points on the spindles. I destroyed a rear tire, don't know how and have yet to buy a proper replacement.
One trick I do and this is your call is that there are stop bolts on my swing arm (keep the arm from over correctiing). If you look close you can undo the stop bolts, and line up the holes on the swing arm and lock off the mower deck (this will make more sense when you get it the mower, but I can send you pix if you want). What I do is I lock off the mower and then I am able to raise it up and get it over top of stubborn plants and and also use it to mow steep walls (we have a 60 degree cut bank that I park on the road and press the mower up to it).
Mowing a slope is scary stuff. Really. The seat on the 1850 takes some HUGE getting used to. I am VERY tempted to do Kens upgrade as my kidneys can't take much more of this.
When I first mow a slope I am unsure about the angle on, I go up and down. or at the worst 45 degrees to the angle of the slope (across the slope yet heading down). Once you begin to realize that it is pretty impossible to tip the 1850 you will get more secure on cross mowing.
To get the most traction out of the PT you need to reduce the air pressure in the tires. Like down to 8 to 12 lbs. Ken can give you more info. Frankly I don't do that agressive of a slope (45 degrees) very often, and when you reduce the air you get all sorts of other issues, so I run at about 15lbs or so (I also have tubes).
One thing is that the 1850 slides. you have to get used to this when mowing sideways on a steep slope, You kinda point the nose uphill, but the back of the chasis pushes you straight across.
Mowing on wet grass when it is super steep is pretty dicey. Even when dry the cut grass will create moisture and it will get slippery.
Ken and I have lots of maintenance tips for the rest of the machine, but this should get you started.
Oh, Funnest thing every... Get out on your steep meadow, and start doing figure 8's on the hillside. That is how I figured out how powerful this machine is.
PS. You owe us some serious pictures of what you are dealing with.
Carl
/ hillside mowing techniques #11
Ditto on Carl's comments.
I was out on wet grass over the weekend on steep slopes, and traction will be an issue. Seemingly dry grass crushes and it gets slick in a hurry.
All the best,
Peter
Peter and Carl,
Wow! Thanks for the brain dump. I'm looking forward to putting these suggestions to good use. I long ago read your (and Charlie's) thread on making up heavier blades so, assuming they are not available off the rack, I intend to do likewise. In the meantime I'll see how much the PT blades can take on the first run. Are there any "standard" replacement blades that I can order off the shelf?
As I am buying from a private party, the unit comes as is without extra blades. The good news is I managed to find a good deal on an essentially new unit (less than 400 hrs), so I'm hopefully not facing the immediate maintenance issues I experienced with my 2445.
When I was a kid we lived on a hiily street. One of our favorite activites was to fly down the steepest hills in a go cart frame (no engine at the time) and "drift " through the gravel curves. As I got older I confess more time than should have been was spent spinning donuts in parking lots...so I get what you are saying about the sideways slip. I think I'll be fine with that as long as there is something other than a dropoff below me. What a great suggestion to do figure eights to get the feel of what the beast can do.
I'm really looking forward to having this mowing capability. I'm also thrilled to be able to use other implements we have on either of our tractors. In addition to mowing we're facing rebuild of 4 greenhouses (collapsed under heavy snow load), putting up a pole barn and hoping to begin framing of our timber frame house this year, so having two units is going to come in handy. My 21 year old step son is itching to learn how to run the mower, so after I get the feel of it I may lapse into Tom Sawyer/Huck Finn strategies to maintain...
I'm waiting for two parcels to arrive - one is 23 fruit trees and the other is 5,000 wasabi plantlets from Japan. Assuming they arrive by Thursday, I plan to head up Friday morning to meet the tractor guy. Unfortunately the weather forecast after that is several days of rain (which we need badly), so serious mowing may have to wait....
at any rate I'll snap some new photos and do a more detailed review of the proceedings. Here are a couple of shots in the meantime....
Thanks again for all the feedback, caveats and encouragement!
Best,
/ hillside mowing techniques #13
That's some beautiful countryside. I'm retiring to the opposite side of the Smokies, just south of Gatlinburg. That's where I put my little PT-425 through its paces...
/ hillside mowing techniques #14
WOW. That is one great property. How big is it? I love the tree house, I assume the home itself is just as cool?
Can't wait to hear about all the aggravation with the PT. Oh, from the pix you should not have too many issues.
/ hillside mowing techniques #15
Hey Ken,
Tiny steps. Don't do it all at once. We moved from seven acres three years ago to twenty acres and I'm not a young pup anymore. The pasture will be no worse for wear if it takes a little time.
/ hillside mowing techniques #16
There's 400 hours and then there's 400 hours - just ask Carl or myself. I think Carl's had much less. Ours were heavily used (abused?). I sent them to PT to go over when we bought them and spent quite a bit getting them to be more normal in condition but still definitely used.
Having said that, i love that tractor. I hope you enjoy it as much as we do. Seat time is so much more enjoyable knowing you can safely go on the slopes and that you can easily change implements.
There are some pictures on my web site showing some of the maintenance locations etc. and some mods.
Ken
Carl,
We purchased the land about ten years ago...75 acres of steep mountain forest, ranging from 3800 ft to 3200 ft, crossed with old logging roads....several year round springs and a nice steam provide ample water and possibility of micro hydro installation to provide all the power we need. Fairly remote for this day and age....we're 20 miles from four towns and some of our best views are of national forest. At night we see only a dozen or so distant lights...
We've spent years improving roads and trails, clearing, digging ditches, putting in culverts, trenches for pipes and elec and such. Our abode at present is a very modest tin pole barn about 30 x 24 feet. We closed in and insulated half of it into what I call our single-wide. Concrete floors heated by water heater keep us cozy against the winter cold.
In shoulder seasons and summer we're content with our camp where we have all the basics....running hot and cold water (gravity fed from spring), electricity and satelite internet, but we look forward to the house. It will be cool when it is built but at present we have only the foundation and a stack of beams. Our PT 2445, with 2500 lb lift capacity and nine foot reach, will come in real handy when we go to place them. The design is our own but inspired by traditional Japanese farmhouse...kind of a blend of old and new.
I'm schooled in myriad aggravations with PT's. I won't bore you with details, but suffice to say I've been shoulder deep in the snake's nest of hydraulic hoses more times than I can count in my years of PT2445 ownership.
Ken,
Of course purchases of used equipment often come with good tales, but taken at face value this unit appears to have been used for fairways in Florida...the only negative is the 90" mower is a finish mower, not brush cutter, but I think we can work with that once we get the bruch cleared. A SE eguipment dealer picked up two PT1850s from a Florida bank that took them back and didn't know what to do with them. As he too is a flat lander, no one in his area knew what they were or what they were really capable of, so I took one off his hands ;) Only time will tell if I'm lucky as to its "true" condition.
Whistlepig,
Your words are wise. I too am no spring chicken and although I often forget I'm not 20 anymore, I'm "trying" to slow down and do things smarter. Alas, at the same time I feel a sense of urgency to accomplish what I can in the available time....I've always been driven and I doubt that will change much... That said, you don't know my lovely wife who will not let me rest until she can see grass in the fields again.....
Kent,
We're practically neighbors...let me know if you ever wander our way
Picture of the current "house" and accompanying bathhouse attached...
Best,
/ hillside mowing techniques #18
Way Friggin Cool!!!!.
I am going to skitter off topic for a moment. I am a huge fan of japanese architecture. The rough open beam design is way cool. Just not sure how it will hold up in the cold ;-)
T Fujii Japanese Antiques (Honolulu, Hawaii): Antiques from Japan
We are going for a more modern design, Think Turkel or Dwell in terms of architecture. Lots of glass.
I saw this and thought you might be intrigued in as you seem to like japanese architecture. It is a burned cedar siding. Makes the walls bug proof and adds a very interesting color to the overall plan
http://materiadesigns.wordpress.com/2009/12/27/shou-sugi-ban-terunobu-fujimori-charred-cedar-siding/
Something I love personally with this technique
Wabi House by Sebastian Marsical Studio KARMATRENDZ
Anyway. Ken and I will be around to help you as possible. You got a way cool machine. Too bad on the mower. Can't wait to see pictures of what you get. May be a simple change to get it more brushy (PT is not known for making too many different designs).
Carl
Thanks Carl,
I use the term "inspired" by traditional Japanese farmhouse rather loosely. This will not be a truly traditional design, more of a blend between Japanese timber framing and more modern construction. Combination of SIP panels on the roof over the exposed beams and foam insulation in walls together with significant thermal mass, hydronic heat and venturi cooling should keep it comfortable. Full height windows cover more than half the walls to let the outside in. Poplar bark (harvested from our land) will be the siding with locust posts holding up the porch roof and trimming the corners. Wide board flooring...no drywall at all.
I spent 15 years as a designer/craftman, mostly building custom contemporary furniture and architectural fittings for office, churches and residences. Now I'm little more than an arm chair designer and backwoods hack carpenter, but during that time I came to appreciate the sparse simplicity of Japanese design. Great links!
my lovely wife is an award winning high end interior designer...in the course of her work she has specified many a project using reclaimed timber...so much so that her main supplier/friend is literally GIVING us all the timbers and wood that we need to frame, trim and panel the house. In addition, he has a crew of Amish lads that are going to bring materials to the property, set up camp with us and erect the frame per my directions. also providing and installing reclaimed green-patina slate roof. the whole concept gives me (good) shivers...i feel very fortunate to be a part of it and see it come together.
thanks so much for all your suggestions. I have mused about converting to a rough mower and will likely tackle that if warranted
