wolfpack2
Gold Member
Looking at the pictures you attached, it would appear that there is a Scotch-Lock used to jumper the two wires on the switch. If you remove the jumper, the switch should again prevent starting until you reinstall the switch back to the proper location. You will also need to repair the damage the jumper has caused to the wires.
