Canopy About to buy a 3000 series JD (enclosed cab)
   / About to buy a 3000 series JD (enclosed cab) #1
ShhDragon
Killingworth, CT
Wondering if it has windows that open, of if a panel or two can be removed to have partial open to the elements but partly closed/protected.
I noticed that Kubota seems to have this.
   / About to buy a 3000 series JD (enclosed cab) #2
The back window opens and has pistons. No side or front windows. There are doors on both sides but is recommended to use only the left, control levers are on the right. It is easy to open the right side if wife comes up to that side to give new how-tos and what-tos.:D
   / About to buy a 3000 series JD (enclosed cab) #3
I opened one of my lower front windows with one of my loader arms :mad:
   / About to buy a 3000 series JD (enclosed cab) #4
accidentally of course, and it cost me $100 to replace myself.
   / About to buy a 3000 series JD (enclosed cab) #5
I prefer to just turn the handle to open a window. Lot less glass to clean up.:D
Perfect. The piston-held back window is just right. Any other thoughts on the value/worth of enclosed and its higher price would be appreciated. Thanks
   / About to buy a 3000 series JD (enclosed cab) #7
Having gone from an OS for years to a cab I can mention some points although have had the cab model only about a month (42hrs already!). It is a pain to climb in and out when just doing odd chores here and there. You are also a little more detached from doing fine work like using FEL or tilling but after awhile you adapt just the same as a semi driver does when transitioning from a personal car to the big rig. Controls do not seem as responsive but you learn to feather them and I attribute some of that to newness, they are starting to loosen up a little. Not much downside for me. On the plus, the cab adds weight which is a good thing. However the whole purpose of a cab is climate control and for that I could not be happier. It is pressurized which means the dust and dirt do not get in. Mine is sealed so well that I have to crack the back window open to get the door to shut tight. Don't mind doing that, has already become habit. Cold windy days I'm still out getting work done where before I would have avoided it. Tilling garden yesterday with wind blowing and dirt rolling around the back did not bother me a bit for the first time and I look forward to not having all of those dandelion white things flying into my eyes when the mowing starts up. Did not get it in time to use during a snowstorm which is why I got it in the first place but have had some very cold days out smoothing the driveway and that cab gets toasty warm very quick. Have been out using the FEL on some warm days lately and the AC keeps it very comfortable. One last thing, being able to hear and enjoy a radio/CD player sure makes seat time even more fun. Oops, one more thing. Having the beverage of your choice at your fingertips without dirt, grass, or bugs on the rim of it to clean off is nice!
Kind of a windy post but a cab is not for everybody or even very good for every situation. Simply a personal choice.
   / About to buy a 3000 series JD (enclosed cab) #8
If snow clean up is a major reason for purchasing the tractor then you will like having a cab. I prefer cabs to OS for most things but it is a personal choice.
   / About to buy a 3000 series JD (enclosed cab) #9
Walkie Talkie Radios come in handy when working around with a 2nd or 3rd persons on the gound. Allows you to communicate without having to idle down, open the door, and shout at those on the ground. When I'm outside by myself, I keep a walkie talkie in the cab and one turned on inside the house in case i need to call for help.
ArkLaTexSam
   / About to buy a 3000 series JD (enclosed cab) #10
I love my 3520 enclosed cab. keeps the wind & blowing snow out of your face, helps with my allergies in summer, keeps the ticks off of me, and its fun to watch the upset bees bounce off the cab glass when they get stirred up....
Tony
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2019 GENIE S-45 BOOM LIFT (A52709)
2019 GENIE S-45...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A58214)
2015 DRAGON 137BBL...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
