Tractor Sizing What Size More/Deck for 1 Acre ? 20 Acres ?
   / What Size More/Deck for 1 Acre ? 20 Acres ? #1
Katmandu
Looking to buy a mowing tractor soon.
What size engine and deck is ideal to cut 1 Acre ?
Also, interested in a mower to do a 20 Acre lot. What size tractor/mower deck should I consider ?
TIA:confused:
   / What Size More/Deck for 1 Acre ? 20 Acres ? #2
Welcome! Lots of guys really favor the zero turn mowers - for lawn mowing. What are you mowing, how often, how smooth is the land?
   / What Size More/Deck for 1 Acre ? 20 Acres ? #3
Are you talking about 20 acres of rough cut or lawn?
   / What Size More/Deck for 1 Acre ? 20 Acres ? #4
Welcome to the forum.
How much time do you have that you want to spend mowing?
Both areas the 1 Acre lot is a residential lawn. Just need a inexpensive mower for this job. Not sure what size to get.
The 20 acre lot will be rough cut. It's unfinished land that our Neighborhood Association "may" be acquiring soon.
For the 20 Acre lot as little as possible. Folks would be volunteering their time to cut it so time would be of the essence.
   / What Size More/Deck for 1 Acre ? 20 Acres ? #7
for 1 ac.. a scut and 5' finish mower would be ok.. for 20 ac.. if we are talking finish mowing.. then a cutand perhaps a 7' rfm
soundguy
   / What Size More/Deck for 1 Acre ? 20 Acres ? #8
If time is of the essence then you need to base your decision on cost. How much you have to spend?
   / What Size More/Deck for 1 Acre ? 20 Acres ? #9
also.. are you looking for one machine to do both or two machines?
will they stay on property or be hauled?
finish mowing only?
soundugy
   / What Size More/Deck for 1 Acre ? 20 Acres ? #10
I have a 50" scag zero turn that's rated at 3.8 acres per hour. They may come a little smaller but not much. As far as the 20 acres, I'd go for at least a 7 footer and it's still goig to take sometime. If finished grass on the 20, you'd be better off with a 6 foot commerical mower. They'll do about 7.5 acres per hour.
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
Deere 35P (A53317)
Deere 35P (A53317)
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
