Slacker
Gold Member
Backhoe stabilizer, dipper and boom cylinders drift down after a day or so. Using the transport tabs isn't an option. I'd like to use check valves to hold the boom and stabilizers where I put them. Any reason i can't do this?
That will work unless you have piston leakage and it will still leak down.
That depends on how cylinder is hooked up...pressure on capped side and pilot checks on both capped and rod side will "seal the deal", even if piston seal leaks. It can not drift unless rod seal leaks externally.
We had a video clip about this a few days ago
I was sure that the cylinder would drop some before it equalize. What say you.
The volume for the displaced "rod" is the "missing link".....
Are talking about drifting down during transport or when using the stabilizers to support the tractor while digging?
Most stabilizers come factory equipped with P.O. checks on them to lock them down when supporting the vehicle while digging.
Be very careful about P.O. checks on both ends of a cylinder. If stored cold and then brought out into the sun thermal expansion can blow cylinders apart.
Roy
I am curious why you do not want to use the transport tabs? My old backhoe dropped alot faster than in a day and for what I used it for did not think was worth the price to fix it.
Yes good point. I forgot about that too.Most stabilizers come factory equipped with P.O. checks on them to lock them down when supporting the vehicle while digging.
When I take the BH off the tractor, I need the stabilizers and boom to lift it off the subframe. They then leak down making it a PITA to get things lined back up when I want to reattach. In my mind, if the boom and stabilizers had check valves then they would not be allowed to leak down, making re-attachment much easier. I'm just looking for a way to keep the BH in the same position as when I left it. Getting the PTO pump hooked up then re-positioning it is time consuming because of the leak down issue.
I see what your saying. Can you use something like bottle jacks or a preset size of block that you can back up to and use backhoe to lift rear end up enough to slide blocking under? (Just a thought may not be possible.)
Backhoe won't pick up the rear of the tractor. Wouldn't even come close, even when it was brand new.
PTO pump or tractor hydraulics, makes no difference.
something isn't right every backhoe I'v run would lift the tractor are you sure pumps are working correcly
maybe I missed it but what type of tractor and hoe do you have?
tom
Farmtrac made the hoe in Tarboro NC. It's the 4008 model. Curl seems strong enough but the other cyliders seem weak to me. I do have oversized loaded rear tires. I've run the hoe on the tractor hydraulics and a PTO pump. No difference in strength that I noticed.
Have you run many compact tractor backhoes or just commercial ones? Eventually I'll plumb a pressure guage in and see what I've got for pressure. I've always suspected the relief valve needs to be set higher but I'm new to hydraulic's so it's a little intimidating.
