best solvent for cleaning engine?
/ best solvent for cleaning engine? #1
gary_g5
My engine is completely covered with oil and grease and debris. See the picture below. I need to clean the alternator coils and areas that have non-metal components. All the engine degreasers I've seen say they can only be used on metal and not on wires, plastic, or paint. So what should I use to clean everything?
/ best solvent for cleaning engine? #2
Wow! Lots to clean, do you know anyone who has a steam jenny, as that would do the job. Of course you would have to cover the area or collect the run off as your steaming engine.
DevilDog
DevilDog
Nope, I don't know of anybody. I live in a rural area and it's a long way to the nearest shop, and I don't exactly get along with the folks there, so I'd rather do it myself.
/ best solvent for cleaning engine? #4
I like Simple Green but I'm not sure that will handle even your problem!
I've used it many times to clean/degrease engine bays in vehicles. Never had a problem yet.
/ best solvent for cleaning engine? #5
Brake cleaner such as Brakleen from CRC This stuff is amazing- we use this all the time in an industrial shop with heavy equipment.
Some manufactures of brake cleaner also make clorinated and non clorinated forumlas.
/ best solvent for cleaning engine? #6
That Purple power stuff is great too!!
/ best solvent for cleaning engine? #8
I have used kerosene in a sprayer, let it sit overnight or at least a couple of hours then pressure wash it. What you miss or is not removed just redo it and wait a little longer then do it again
Just don't have the EPA or environment cops around
I have used this for many years and it is a cheap way to do a tough job
Regards
DGS
/ best solvent for cleaning engine? #9
brush, scraper, soap and water and some of the above mentioned degreasers, but be real careful around the wires. Thats one nasty looking grease. Is that normal? Haven't seen something like that in years.
I had a crankshaft oil seal go bad awhile ago, started blowing oil all over towards the end of fall. Also had a mouse make a nest in front of the flywheel screen and another on top of the engine around the carburetor and didn't know before I ran awhile. So it's kind of an oil/grass/mousepoop combination that covers everything. I was also getting a battery charge indicator light before I took it apart even though the battery was fully charged, so I think the alternator wasn't working at full steam because of all this gunk. Think I can just clean it, or will I have to replace it?
/ best solvent for cleaning engine? #11
1st I'd start by scrapping as much as possible, use a screw driver and small paint scrapper. Then you could use kero, WD40, Hand goop, dish soap, shampoo, vinegar, carb cleaner etc.... Personally I like stuff that won't kill the environment, or catch the run off of the nasty chemicals. If you have a compressor harbor freight has a neat little high pressure washer that acts some what like a sandblaster. Just mix up your soap/cleaner{instead of sand} and start spraying. I've used mine on car, tractor truck dozer and motorcycle engines, worked pretty good IMO.
/ best solvent for cleaning engine? #12
I'm surprised no one has mention oven cleaner, a few years ago I was told about this Biodegradable stuff from Walmart ( Oven cleaner ) and been using it ever since, way less expensive then the engine degreaser and even works better,;)
/ best solvent for cleaning engine? #13
+1 for the purple stuff. The Walmart brand works well. One is called Power Purple and the other Purple Power I think...:confused: might be the same stuff. Spray it down and let it sit a few mins then hit with hose or pressure washer. Lather, rinse, repeat until clean. Using a throwaway plastic brush helps loosen really thick stuff.
/ best solvent for cleaning engine? #14
Regards
DGS
That's what I'd do also. I'd spread a plastic tarp out underneath it to catch the dirt & runoff.
/ best solvent for cleaning engine? #15
One more thing, if you're using kerosene or regular brake cleaner to clean up, have a fire extinguisher right there. Spending the extra 30 seconds to get it now is way better than the extra minute of raging fire in the engine while you run for it by the shed door. :eek:
/ best solvent for cleaning engine? #16
I'd protect any moisture sensitive parts and do as others have recommended... for the protected areas...you might be amazed at how well just high pressure (dry) air will do in removing gunk etc...especially with a few makeshift nozzles...
Remember to avoid blasting dirt,grease etc. into seals etc when using a compressor or pressure washer...
/ best solvent for cleaning engine? #17
I worked for many years for a company that made electric motors and we had all kind of cleaning tanks. The only thing you want to be sure of is that whatever you use won't soften the coating on the wire used in the rotor and stator. We used Toluine (sp) but I'm not sure it is available to the general public. It sure cleaned any grease or oil on anything.
/ best solvent for cleaning engine? #18
Consider the fluid a dry cleaner uses. used to be varsol don't know the new type but still cleans things. And some that have a dry cleaning co. will sell the used fluid after they changed for new. Of course use all the safety required for any cleaning material. all liquid used for cleaning in Calif. causes cancer
For small uses I also use engine cleaner in the foam can from W/M.
Simple green straight for the large. then flush off with water.
ken
/ best solvent for cleaning engine? #19
All of those cleaners that have been mentioned are good, but the OP needs one that doesn't hurt electrical components.
Where I used to work, the electricians used a spray can of something called "Lectra Clean" made by CRC.
They would pull apart electric motors and spray them out with this stuff.
It would clean the grease off wiring, brushes, armatures, etc.
It works a lot like Brakleen or carburator cleaner in dissolving crud. And it would dry pretty fast, leaving no residue.
I don't know if Lowes or HD would carry that kind of cleaner, but I bet an electrical supply place would.
Ronnie
/ best solvent for cleaning engine? #20
I'd be inclined to wet it good with kero and let sit. Then sprinkle some Tide (or other detergent) over it. Let sit a little bit. Then use a water hose to remove crud. I'd certainly NEVER use a power washer. Those seals weren't designed to take that kind of pressure.
Renting a steam cleaner gizmo may be the best way to go.
Ralph
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
KBH Tender (A63118)
KBH Tender (A63118)
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2019 WACKER NEUSON EZ36 MINI EXCAVATOR (A62129)
2019 WACKER NEUSON...
