Looking at MF 2625
   / Looking at MF 2625 #1
Hoosier Hay Man
Indiana
Kioti DK45S Cab, Quicktach FEL
Need info on the 2600 Series. Good and bad.
   / Looking at MF 2625 #2
i got a 2605 and i love it. I bought a 2625 mfwd with fel and it was not a good tractor at all. i called dealer next day to come pic it up. it would die if i put the tractor in any bind. it would not go up the a small hill. i decided to go with a case farmall 70 mfwd with a fel and it is a great tractor for about the same amount of money for the 2625.
   / Looking at MF 2625 #3
I am demoing a 2625 this weekend. I will be using it on a 7 '10 disc mower and a M&W round baler just to put it through some heavy work. We want to see how much fuel it burns and if will live up to the hp&torque claims of the simpson engine. Will report back on it in a few days. scrapironford
Who makes the Simpson Engiine?
I cant wait to here how it will preform. I will be using it to make hay, move bales and clean the barn out. Thanks!
   / Looking at MF 2625 #5
Simpson engine is made under a Perkins license in India. They have been building them for 40plus years. This one is a 3.3 litre na 4cyl engine. With what we are going to do with it,it will be maxed out. This disc mower & baler are hp hogs, been running them with 85-100 hp tractors. scrapironford
   / Looking at MF 2625 #7
I own a MF2615 and it's a great tractor!
The Simpson diesel engine is very reliable and has plenty of power.
   / Looking at MF 2625 #8
Update on the 2625. We need to remember this is an economy 50hp utility tractor. It was a 4x4, 8x8 shuttle with ind pto. If you want or need this size tractor with bells and whistles, this tractor is not for you. The 2625 uses a time tested proven design,limited electronics and manual controls. I had some minor problems to begin with,about 2 qts water in the fuel, in less than 30 min the owner of the dealership personally delivered me 2 fuel filters,as I had already drained the tank. The other problem was a filter came loose,my fault. My disc mower is an old greenland group that has a high hp requirment,I mowed the thickest, rankest Bahia I had,baled 7 rolls per acre.The 2625 could only pull the disc mower at 4.5 MPH and used about 2.5 gl fuel per hour. Lets be fair, the oliver 1855 could only pull the mower at 5MPH and used 3 3/4 gal per hour,in this grass. In young bermuda grass it cut at 5 1/2 mph and worked a lot less, Next I tedded a field of hay, had to look in the fuel tank to see if it used any fuel. I then raked 9ac with a 10 wheel rake, same fuel use as tedder. Now comes the test, M&W4500 round baler. It had all it wanted as this baler it is hard to run. After 3ac I switched tractors,MF492, as to not abuse the 2625, it run it but not great. I also used it on a deere 466 baler,4 rolls just to see what it would do,done a lot better with this baler. Just before the demo was done we used it on a NH 268 sq baler just to get the baler working, it didn't even know it was there. I don't need a 50 hp 4x4 tractor although it might be good using the loader. The trans is nice and easy to use. If you rest your foot on the clutch, I did at first to comfortable, your clutch might not last very long. With this size tractor I prefer a LIVE PTO for what it is used for instead of Ind pto. The Simpson engine was smooth as a perkins and seemed to produce its hp on a minimum of fuel. It done everything I asked it to do. Didn't have time to use it on any tillage equipment. This might be the best tractor in its class for the dollar? I don't know yet, still have 2 or 3 more to test. scrapironford
Thanks for the update scrapironford! No frills is what I am after. I would want the live PTO also. I would hope it would be less thirsty than an Oliver. I love driving an Oliver:D, smooth runners, but they can be a bit hard on the fuel budget(the gas burners):eek:.
I still haven't decided yet on what will be my next loader tractor. It is down to Deere, Massey or Kubota. They have the best dealer network in my area with at least 2 each to choose from within 30 miles.
Nice Tractor!!! Thanks for the info. Now that tractor has some steel in it!
1998 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
1998 JCB 930 ROUGH...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
(2) DOUBLE AXLE FENDERS (A54756)
(2) DOUBLE AXLE...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
