Got my M7040
/ Got my M7040 #1
Lyrch75
Leetonia, OH
ZD331 and RTV1100
I have had CUT and UT tractors for the past 10+ years. Started with a TC24, then went to a TC40 and then a TC55DA. The first two blue tractors were fine, just too small.
The TC55DA was great until 150 hours and then I had to put a grand worth of repairs into it. That sorta destroyed my faith in the blue.
So when I went shopping for a cab tractor the options were green or orange.
Ended up going with the Kubota for two main reasons. 1. Was a good bit less expensive than a comparable JD. 2. THe Kubota dealer is within road distance.
Yesterday got a call they had the FEL mounted and were waxing the tractor. I hop on my TC55 and drive it over to the dealer and go home with my Orange machine. It had .6 hours on it at that time.
Things I already really like about the Kubota.
The cab is soo quiet. I was talking on my cell phone when I was mowing a field.
The additional 25% pto hp makes a huge difference with the mower. The field I was mowing is about 10" tall grass and I was only slowed by not wanting to screw up breaking in the tractor. Otherwise I probably could have been in high range. The TC would not do that field above M3.
The loader's speed, it is a fair bit faster than the 18LA that I had grown accustomed to.
Things I am going to have to get used to.
Have R1's on the KUbota, had R4s on the past two tractors. The added height and reduced width make the tractor feel very tippy compared to the TC55.
The need to slow down to change directions. THe TC's tranny allowed me to flip the shuttle forward or reverse at any speed and it would do its thing. The manual states I need to slow dow to do this with the M7040.
Slight vision reduction with the loader. THe 18LA had the long single piece upper beams where as the LA1153 on the K has a traditional constructed beam.
Added height of a cab. Found more than a few trees I will be trimming to be able to mow, as I really do not want to abuse the cab's finish (or structure)
It now has 6 hours on it, so I am certain I will come up with a few more likes, things to learn, and probably a few dislikes as I run it more.
/ Got my M7040 #3
Congratulations on your new 7040!
You mentioned a tippy feel, are your rear tires loaded?
Let's see some pictures now!
/ Got my M7040 #4
I have felt "tippy" on my new M7040 once or twice. I think it is more me than the tractor though. I never felt that way with my old IH 424 in the same position. I think it's got something to do with being higher on the M.
Mine has loaded R1's, cast hubs, and bolt on rear weights.
Congrats on the new purchase, I think you'll like it. I am loving mine.
/ Got my M7040
I think it is the higher seat and the different sightline with the LA1153 loader.
Ran the TC55 without loaded tires, starting the M7040 out w/out loaded tires as well. I just always had something on the back of the tractor usually around 1000 pounds.
Will see if I get more comfortable with the feel and realise it is the seat height, or I will put it on its side, like I have done with several other tractors over the years
Pics will be up once it quits raining and I can get my camera charged :D
/ Got my M7040 #6
Sounds like you did real good with the M7040!
Ditto on the pole saw!!!
Those cab roof marker lights are expensive!!!! Don't ask how I know!!
Stu
/ Got my M7040
Stu
I almost got to find out how expensive a mirror is :eek:
/ Got my M7040 #8
Hey Lyrch,
Congrats on your purchase...Is this unit an 2009? If so, does the motor have a turbo? I found conflicting info on Kubota's website.
Thanks in advance and good luck with your tractor...
Jimmy Mac
/ Got my M7040 #9
Congrats on your tractor... I jealous with envy...
You may want to load those tires on your tractor...This should help some with the "tippy feeling"...
/ Got my M7040 #10
I looked at that size Kubota as well as the next two sizes up. I ended up getting a JD 5525 because the cab was larger and I could get a 2nd seat option. Anyway, both the Kubota and JD tractors came with R1 tires. That's fine for certain circumstances, but with loaded R1 tires, an FEL and a decent sized rear implement, I was weighing so much that I couldn't go across a lot of places without leaving ruts. I found on both the JD and Kubota that all I needed to do was find the aspect ratio for the front vs rear tires and go from there. I ended up buying a spare set of wheels and tires that are R4 tires.
I find that I mostly use the R4 tires since not only am I lighter with them (as opposed to loaded R1 tires), but the R4 tires have a much thicker carcass and are much wider along with putting larger lugs on the ground. This allows me to use the tractor in places I couldn't consider with the heavy and relatively narrow R1 tires. I don't recall off the top of my head where I ordered the wheels, but I'm pretty sure I posted where on here somewhere. By purchasing "blemished" R4 tires to go on my new wheels I ended up having about $800 or so total in the 2nd set of wheels and tires.
/ Got my M7040 #11
Congratulations on the new 7040!
That is the size tractor I needed but I found a deal on a M95. I love the tractor, the power is awesome. I'm finding out the cost of the bigger implements is also awesome. :(
Have fun.
/ Got my M7040
Hey Lyrch,
Jimmy Mac
'o9 was delivered to the dealer on March 26. It does have a turbo.
I had the same confusion as to if the 7040 was or was not t/c, so I just looked under the hood when I was at the dealer one trip.
/ Got my M7040 #14
I stopped by and checked my dealer last night. The M series (6040 and 5040) they had all had turbos if they had a -1 after the model number. ie: M6040-1.
I just bought a non turbo M7040. Would have gotten a newer turbo one but they didn't qualify for the 60mo financing and were $4k more around here.
/ Got my M7040
Gotcha. The M7040HDC-1 is the model designation for mine.
Mine was the 0%, so long as the dealer reordered a comparable tractor. The dealer I went to has a couple old greenhouses that he keeps his stock in so he didn't mind getting a late season tractor in.
/ Got my M7040 #16
That's very interesting about the turbo charged models. Kubota's website shows some information indicating the turbo charged models, but other pages (specifications) doesn't mention it.
The literature I picked up at the dealer yesterday didn't mention it, nor did the salesman.
It looks like the turbo charged M7040 has about 2 hp more on the PTO.
Is the turbo worth it? Turbos are expensive to repair if they have problems.
Ken
/ Got my M7040
Ken
It seems to do a nice job with holding the motor at the 2160 or so you need to run at 540. I have mowed a few pastures and it gets a bit boring watching the digital dash read out 539, 540, 539, 540... don't know if it is that way with Kubota's other electronic motors that lack a turbo, but I know it I haven't encountered it on other tractors.
/ Got my M7040
Finally putting a picture up :D
little fuzzy, but whats a bit of bad focus amoungst friends ?
/ Got my M7040 #20
You got paint on your bucket!!
I've got an M7040, had for about a year. No cab, but don't really feel the need for it, except when you run a baler.
Your going to like that tractor.
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
UNUSED TAG BTB12518 - 18" PIN ON BUCKET (A64280)
UNUSED TAG...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
US ELECTRICAL TOOL CO.-500B BALL BEARING GRINDER (A64280)
US ELECTRICAL TOOL...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
