Update: kubota weightbox & land pride qh-15 are incompatable
/ Update: kubota weightbox & land pride qh-15 are incompatable #1
shrekbelly
guys,
my silly saga continues with my bx2360, weightbox and land pride qh-15 series quick hitch.
dealer came out and made the accessment that they were incompatible from a couple standpoints, without major (jerry rigging)/modification.
my bx truly needs the weightbox for the fel work and snowblade work. to say that i'm a bit miffed and p.o.'d at the same time.
from jump street, i intended to have implements on dollies. i didn't want to have to horse implements around on dollies! . . . i bought into the quick hitch dream.
it makes no sense to take the lp hitch off to accomodate the weight box. i went with the land pride hitch because (right or wrong), i thought it was a very sturdy alternative to some of the other quick hitches available . . . a partner to kubota and would require less hook up steps than pat's easy change system.
anybody have a kubota weightbox on a land pride qh-15? what modifications did you make
regards, shrekbelly
/ Update: kubota weightbox & land pride qh-15 are incompatable #2
/ Update: kubota weightbox & land pride qh-15 are incompatable #3
Fill your tires!!!
My 7510 has loaded tires and there is no need for a weight box. In snow or with the FEL. I max out my FEL at about the same point the rear tires come off the ground when driving...
/ Update: kubota weightbox & land pride qh-15 are incompatable #4
Fill your tires!!!
Agree. Fill the tires. I don't even have a weight box and do allot of FEL work and plow snow. I have not needed any additional weight. The three point can better be used for more useful tasks then a weight box.
flatlander
i agree, there are better uses for the 3pt hitch. i have 55 lb wheel weights for the rear.
hookopotomous regards, shrekbelly
/ Update: kubota weightbox & land pride qh-15 are incompatable #6
flatlander
hippopotamus regards, shrekbelly
Sounds like you have the weight covered and if you need more, filling the tires will take care of it. I really like having my filled tires. My last BX did not have filled tires.
Now on the Three point quick-connect...That is on my short term wish list.
/ Update: kubota weightbox & land pride qh-15 are incompatable #7
I prefer wheel weights. The last thing I'd do would be to load the tires.
/ Update: kubota weightbox & land pride qh-15 are incompatable #8
Fill em and forget em... I plow snow, romp through the woods cutting firewood, mow my lawn....No problem eh...:D
/ Update: kubota weightbox & land pride qh-15 are incompatable #9
Gotta remember, Art sells weights, which typically cost double or more per pound than liquid ballast. I'd have all wheel weights, too, if the cost was equal.
/ Update: kubota weightbox & land pride qh-15 are incompatable #10
Some implements are simply not compatible with any quick hitch. It is just one of those things and it has always been that way since quick hitches were invented. When I bought my first attachments, I was going to get a QH and the salesmen told me this, therefore I didn't buy one. I custom built dollies for each implement instead.
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
500BBL WHEELED...
2024 Chevrolet Tahoe SUV (A59231)
2024 Chevrolet...
