Any ideas what to do with granite cut-out?
   / Any ideas what to do with granite cut-out? #1
Tdog
SE Louisiana
BX22
We recently took the plunge & renovated the kitchen. We kept the old cypress cabinets, but replaced the tile countertops with granite. Itç—´ a little over an inch thick - - it is the piece they cut out for the cooktop, about 2 x 4 in size. It is sitting outside, leaning against the deck & I know SWMBO will start on me to move it soon. Now that I said I wanted it, I am trying to figure out what to do with it. Any thoughts?
Jack
   / Any ideas what to do with granite cut-out? #2
Build a "base" and put it on top for an outdoor table. You could also build it tall for a "bistro" table, then get a couple of tall chairs.
or, cut in in half for two matching tables.
   / Any ideas what to do with granite cut-out? #3
It would make a nice surface for mixing bread or pastry. Perhaps a tad big, but that would be how we would use it.
   / Any ideas what to do with granite cut-out? #4
If you have a wet saw the options are endless. You can cut a piece off to be used as a cutting board. Some silicone applied to the bottom will make it skid resistant while being used. I still have some pieces knocking around from my kitchen re-do. I did use one piece as the sill plate for the kitchen window over the sink.
   / Any ideas what to do with granite cut-out? #5
These make wonderful tops for a rifle shooting bench. I put them on top of a bunch of hay bales at my backyard range. They are pretty heavy so they don't jiggle very much, yet you can move them as necessary to pick up a target card. My 50BMG and my 700Rem are on bipods and these tops work great to provide a stable platform. Add a sand or shot bag for the rear rest and bingo !
   / Any ideas what to do with granite cut-out? #6
Since you already have granite countertops, it's unlikely that you'll need a granite cutting board. I like the idea of making trim pieces out of it. If you need a perfectly flat surface for any project, that granite will be ideal. Also, since it was cut out of your sink opening, you might make half of it a work surface that could be placed over 1/2 of the sink so it is recessed down slightly and would drain water into the sink. That would make a good preparation surface for vegetables or fruits, but might be too darn heavy to be practical.
   / Any ideas what to do with granite cut-out? #7
If you "float" it on a concrete base it could make a nice surface plate in the shop. Could even be used to lap surfaces on if you didn't mind wearing it out over several years. It is just not good for dumping heavy sharp cornered objects onto, like engine blocks.
   / Any ideas what to do with granite cut-out? #8
Had another thought, would make a nice matching "roll-a-round" type work station in the kitchen.
   / Any ideas what to do with granite cut-out? #9
We added a small island in our kitchen as sort of a divider between the kitchen and dinning area. We had room for a trash compacter and a cabinet and drawer. In the top, we cut it out and put the top to our old portable dishwasher which had a cutting board top. If we redo our kitchen counter top we'll put the granite in place of the cutting board.
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55218)
2-Row Peanut...
2005 Chevrolet C4500 Altec Bucket Truck (A55788)
2005 Chevrolet...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
JOHN DEERE 6615 TRACTOR (A54756)
JOHN DEERE 6615...
