4x4 Pick up truck vs. tractor?
   / 4x4 Pick up truck vs. tractor?
Hmmmmmm I wonder what would happen if I hooked my L4200 to my Duramax Diesel 4x4 ??????
You'll never know till you try! Be sure to post some pics:D
   / 4x4 Pick up truck vs. tractor? #43
If weight and traction coefficient were = it would come down to HP/speed where that HP occurs in lowest gear.
larry
larry
I'm guessing the truck weighs 1500-2000 lbs more. In low gear I'm sure either one will have more than enough power to spin the wheels. Angle of the chain would need to be level to make it fair. Wheels speed makes a difference and the truck would definately have more of that. pulling surface will determine the ammount of parts breakage:D
   / 4x4 Pick up truck vs. tractor? #45
Truck will win then based on weight. Good thot on chain hookup. Wheel speed not an issue unless you are moving and throwing huge amts of dirt-jet propulsion;). Best traction is at creep slip rate otherwise.
larry
   / 4x4 Pick up truck vs. tractor? #46
It depends on the surface and type of tires. If the truck has street tires and the tractor has ags, the only way the truck will win is if it is on pavement or very hard pack clay, otherwise it won't be able to put that HP to the ground. Now if the truck has some serious mud tires, like boggers, then the truck will have it in almost any condition. Likewise if the tractor has turfs, I give the edge to the truck in any condition.
Truck will win then based on weight. Good thot on chain hookup. Wheel speed not an issue unless you are moving and throwing huge amts of dirt-jet propulsion[/COLOR];). Best traction is at creep slip rate otherwise.
larry
Actually wheel speed does make a difference. Being a redneck I've been stuck quite a few times and under various conditions while testing the abilities of trucks, 4-wheelers, etc.:D I can say for sure that slow spinning wheels won't get a vehicle unstuck or up a muddy hill as easilly as fast spinning wheels. I'm not sure if this agrees with the laws of physics, but it does make a difference. Partially from cleaning the tires and maybe centrifugal force has something to do with it? I agree that if you can keep from spinning the wheels you're better off though.
   / 4x4 Pick up truck vs. tractor? #49
one of this tractor R3 T 75 75hp
R3 T 75-85-95
vs
a nissan navara 200hp
the winner was the navara
I call BS unless the nissan had some monster ags on it and some serious gear reduction.
I'm not very good at reading the foreign language but could make it out as 4wd and 2900kg which is about 6300lbs. The nissan is about 2100kg which is about 4700lbs. No way would it win unless the tractor was in neutral
Yeah that's a little hard for me to believe too. More info please, any pics or youtube videos? Was it something you personally watched?
SCAN FOR HAULING AND FINANCING INFORMATION (A54757)
SCAN FOR HAULING...
UNUSED LANDHERO CHAINS, BINDERS & DBL CHAIN SLINGS (A54757)
UNUSED LANDHERO...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
John Deere 3PT PTO Post Hole Digger (A55218)
John Deere 3PT PTO...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
