trailering BX25
/ trailering BX25 #1
deerhunter1
Member
I just bought a new BX25 Kubota. I have a Ford ranger 4X4, 4.0L V6 with a class I hitch I think it is rated 3500 Lb. I have a carmate 5X10 dump trailer. Can I haul my tractor? How about with a hitch extension and the bucket over the front? Thanx
/ trailering BX25 #2
yikes! using a hitch extension will lower your towing capacity. a dump trailer will weigh at least 1k. the bx25 with FEL and BH can weigh over 2700lbs. The total with trailer and BX can be over 3700lbs then add in the chains, binders, etc.
Is the dump a daul axel? If so, how much does it wiegh? What's the MAX carrying wieght ? I wouldn't use the extension. You will need to upgrade the hitch on your ford and I hope you will only need to tow it occasionally locally.
Currently, I am towing my BX with a S10 blazer 4.3L with 7k trailer/class4 hitch and its just enough to tow. It tows fine, but like i mentioned in past, a larger tow vehicle would be better. If this is all you have to tow with, if I were you, I would upgrade that hitch or tow your FEL and BH seperate from your BX. The BH is about less then 400lbs and FEL is about 400lbs as well.
/ trailering BX25 #3
Definite NO GO with a class I hitch... only good for #2000 lbs.
Almost certain to be outside the limit of a class II... only good for #3500 lbs.
I've towed my BX 23 all over when I had a 4.3l S-10 Long Bed... Plenty of power to pull... a little light in the rear so I would add #200 lbs weight to the Bed.
My Trailer has 10' rails and was professionally manufactured by a local company back in 1964... The BX fit like it was made for it. I made brackets to secure the loader to the trailer A Frame and had 10 ply tube type tires...
The S10 had a #5000 lbs hitch and that was the limit listed in the Owner's Manual for my Truck.
/ trailering BX25 #4
1*Rangers and S10s are to light duty to toe BXs.
Currently,
1*I am towing my BX with a S10 blazer 4.3L with 7k trailer/class4 hitch and its just enough to tow. It tows fine, but like i mentioned in past, a larger tow vehicle would be better. If this is all you have to tow with, if I were you, I would upgrade that hitch or tow your FEL and BH seperate from your BX. The BH is about less then 400lbs and FEL is about 400lbs as well.
1*not enough tow vehicle.
1*I've towed my BX 23 all over when I had a 4.3l S-10 Long Bed... Plenty of power to pull... a little light in the rear so I would add #200 lbs weight to the Bed.
I'm looking for a 1 ton for my BX23 because I need to haul and dump 3 to 4 thousand pounds of dirt and gravel.
Even if I wasn't needing that I still would not go with anything less than a full size heavy duty 1/2 pick up to tow my bx23 with .
/ trailering BX25 #5
LBrown- you seemed to missed my point here. S10 CAN pull it. The gearing and engine size IS enough for a BX. You be surprised. All I am saying a full size truck that is wider is a much nicer pull and stopping. I am NOT saying S10 is not safe. I am just saying, from a experienced driver, I would feel safer with a larger wheelbase and few more liters for engine. I think the rangers is much more underbuilt then the S-10. However when comparing the chevy to ford full size, the value seems to be better with ford. I am not a ford fan but with todays enconomy I might end up getting a ford to replace s10. ALL I need to do is get a tow rating of 7k or better for towing BX with trailer and that fits many full size trucks now a days.
/ trailering BX25 #6
Good reply and good point.
/ trailering BX25 #7
And almost the mid size line also. My Taco is 6500.
/ trailering BX25 #8
I agree with you. I have seen several toyota's and nissans I really liked too. However from a backup point of view, a full size wheelbase feels good and super easy. No need for mirrors extensions. less sway on road. Just points i wanted to bring up that I am sure you all know what I am talking about.
/ trailering BX25 #9
At the very least you need to upgrade the hitch, and you will need brakes on the trailer if at all possible.
/ trailering BX25 #10
I think that this would work pretty well. The carmate is a little on the small side, as the deck is only 60 inches wide. You want to make sure that you're BX will physically fit. The BX with turf tires says that it's 44.5 inches wide, but you could carry a 60 inch mower deck, and with the discharge chute, it could be wider then you're deck. Also the BX with 3 point hitch is very close to the length of the cart. The cart is 8 foot long. The BX25 is 95.5 inches. You might have to leave off the back gate/ramp. I don't think it would fit with any sort of implement on the back or a BH. If a FEL is attached, it would probably have to hang over the front.
The cart is not very heavy. Probably about 400-500 lbs. The BX W/O FEL is only 1200 lbs. That would put you in around 1700lbs. The FEL is probably about 300lbs, so I would guess a tow weight of about 2000. Well within the towing capacity of the vehicle.
/ trailering BX25 #11
Your truck is fine, just upgrade the hitch to a class III or IV and have brakes put on your trailer if it doesn't already have them (or upgrade trailers). Remember, while a BX25 is fairly heavy for its size, it's basically an overgrown GT with a FEL and BH. So long as you have a trailer with brakes, and of sufficient size to balance your load, that Ranger will pull it fine. A half ton would be safer, of course a 3/4 ton would be safer than a half ton, and if you just put in the bed of an F450 you'd never know it was back there.
The biggest limitation I see with the setup you have now is the 5x10 trailer. It will be fine if you want to haul the BX w/o the FEL and BH (and you can probably manage to squeeze the BX, FEL & BH on there 1 way or another if you must), but a 12' is probably the minimum size to load and balance a complete BX25 and 14' would give you more options. If you watched the trailer wt. you should be able to come in around 4000-4200# loaded, which is well below the Ranger's max. towing capacity of 5600#.
/ trailering BX25
thanx everyone. I made a mistake on the hitch, it is a class III. I think i'm ok on weight although it is a stretch but I would like to haul it without taking the FEL and BH off. My trailer is not a dual axle or a hydraulic dump it's lust a manual dump. Someone on hear hauled with a 5X10 trailer by putting a 14" hitch extesion on and put the bucket over the front of the trailer. Any thoughts?
/ trailering BX25 #13
I would just leave the loader high enough to clear the truck box and forget the extension.
/ trailering BX25 #14
As soon as you install the hitch extension you will loose some of the weight rating of the hitch. Being a single axle trailer you will also have one H of a job trying to position your tractor so the tonque load is anywhere near reasonable. You MIGHT be able to do it for short suburban hauls but I hope that I'm not sharing the road with you once you get over 30mph,,,or on wet pavement,,,, or loose gravel,,,,or on a sharp turn,,,or on a hill,,,,or when a tire blows,,,,.
Even if you could have a longer tonque installed on the trailer it would make things easier
/ trailering BX25 #16
If you're just concerned with getting the tractor home or some 1 time trip like that, then you can probably make do (barely), but it might be easier to either have it hauled, or rent a tandem axle trailer to haul it. If you're planning to haul it with any regularity then it's time to invest in another trailer a few feet longer, with tandem axles and brakes (preferably tandem brake axles). I too would forget about the hitch extension--that's just asking for problems since your load isn't likely to be anywhere near well balanced.
/ trailering BX25 #17
In my response I thought he HAD brakes!!!!
There is a big difference between hauling a load of firewood/gravel etc and a tractor of the same weight...
/ trailering BX25 #18
LOL! It really is a serious issue though--the smaller the truck the more you need trailer brakes.
The Ranger has plenty of capability to pull a proper trailer with the BX on it, but without trailer brakes it'll be a very risky endeavor. Also, if you do attempt to haul it with your 5x10, check to be sure that you're not over any of your wt. ratings, including your trailer tire load ratings. I would really recommend at least renting a tandem axle with brakes.
/ trailering BX25 #19
Deerhunter, I would NOT try to haul that tractor without trailer brakes. (And get electric brakes, so you can control sway from inside the truck with the brake controller.) You can just swap out the axle for one with trailer brakes, and thus do not have to buy a new trailer. (They seem to have gone up in price a lot since I bought mine a couple of years ago.)
As to the extension, I see that some don't like them, but on my F150 I have had no problems, and it does solve the problem of the FEL sticking out over the front of the trailer (although I do like the idea of perhaps welding on a very solid trailer tongue extension instead, as this would be relatively cheap, keep the tongue weight closer to the tow vehicle, and reduce sway as well). However, a big F150 Supercrew is a very different vehicle than the one you have, so the relocation of the tongue weight might be more of a problem for you.
Another option, of course, is to put the FEL or BH in the bed of the truck, since they detach very quickly and easily on the BX25. (Great tractor, by the way - I have the same one.)
/ trailering BX25 #20
I've hauled my BX2230 equipped with FEL and BH in a 5' x 10' single axle trailer rated for 3,500# behind my Expedition rated for 9,000#.
My issues were:
--The sidewall flex in the tires causing the trailer to 'bound' side-to-side with irregularities in the road. Very disconcerting feeling.
--To get a decent tongue balance, I loaded the rig backwards with the BH jammed against the rail to the front, bucket all the way over to one side, and the FEL bucket hanging over the rear gate. It was ugly, but it worked.
--Getting decent tie-downs was a real problem. DON'T use straps...unless you have a multitude of possible tie-down points, you'll never get a nylon strap away from an 'edge'. Use chain.
--Even on the Expedition, which has massive vented disc brakes on both ends, two piston up front, I had a difficult time stopping. I would suspect your truck would have a hard time stopping the load in a reasonable distance.
'Tis your call. Personally, I'd be pretty apprehensive. Not about the trailer, necessarily, but with the limitations of the trailer COMBINED with the limitations of your truck...specifically the brakes. If you had brakes on the trailer, I'd feel much better about the thing.
And leave the extension at home. I cringe every time I see one...a bad joke. Whoever invented those should be shot. They're only good if you're hauling, like, a little tailgating BBQ or a couple of bikes...just dumb for any type of actual weight. If I knew you in the real world, I'd PAY you to NOT use it...
I still use my 5x10 for the BX...
My trailer was built with a long "A" Frame Tongue and cradles the loader like it was make for it.
You would be much happier with 10-ply rated, Tube-Type, Non Radial Trailer Tires... no sidewall issues...
I use a Diesel Excursion that is set-up for 14k trailer... never noticed any deficiency brake wise.
The local Utility Company Tows Single Axle, 8k rated Cable Spool Trailers without brakes... I've often wondered how this is legal?
2011 FORD F-250 SUPER DUTY (A67714)
2011 FORD F-250...
2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
2023...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A68183)
2017 Ford F-250...
2022 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
2022 USA...
2002 Lexus RX 300 SUV (A66738)
2002 Lexus RX 300...
2009 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2009 INTERNATIONAL...
