Backhoe Used Backhoe search for B7200
   / Used Backhoe search for B7200 #1
Spina
Northwest of Boston, MA
B7200
I'm looking for a used BH to attach to my B7200 for some general homeowner projects; walkways, footings for stone walls, drainage, and all the stuff that comes along.
I see various models out there; but, I don't want to strike unless I know I will get a set-up I will be happy with.
Can anybody describe the size, models, and set-up of BH attachments used on a tractor of this size (1200 lbs, 18 hp) and what kind of projects accomplished?
I'm hoping a 3 point hitch set up would be sufficient? I not confident I will find a sub frame kit to match a BH I may find.
I'm thinking it would be best to have a PTO pump to lessen the burden on my seasoned B7200; but, would like to hear others experiences tying into the B7200 system.
Not sure of the max weight of the BH I should expect to hang of the back of the 7200. My reference point is Kubota's recommended BH4672 weighs in at 850 lbs.
I would very much appreciate your inputs.
   / Used Backhoe search for B7200 #2
Sounds like price is a sticking point for you.
BH6000 Woods Backhoe | Cavalier International
$4500
Also the dealer who put on my BH70-X said there were a bunch of left over BH4672's still in the supply chain.
And check 2008 Woods BH6000 Information Haney Equipment Co.
$3K for a new BH seems like a good buy. I have requested a quote and list of other items needed to get a complete set-up.
I'm hoping to get under $2.5K and may need to sell a belly mower to get there. Has anybody put a BH6000 on a B7200?
Any words of wisdom for using a Woods 750 3 ph BH with my B7200 for my typical home owner activity?
   / Used Backhoe search for B7200 #8
Thats 1 word. Maybe 1.5
Sorry
Do Not
There's 3 words.
Search the forums, especially attachments, although I've not seen pictures of a tractor "broken in half" there seems to be a lot of theory that on a SCUT (or generally most tractors under 30hp) a backhoe the size of the 750 can damage the tractor. And I only remember 1 poster saying he did it, but treated it very gently.
My 70BH-x required a fair size sub-frame to make a "4 point" hitch.
You might be able to do it with a special toplink, but then again, might not.
A smaller backhoe might also be doable.
Apparently Woods makes a subframe to attach the BH70X on the B7200HST only nothing for the gear drive B7200. And nothing at all for the BH6000.
Could somebody provide other sources for subframes?
I have found Kubota literature that identifies the BH4672 as a compatibly implement for the B7200 and weighs in at 850 lbs. Does anyone know if Kubota has a subframe for this mount or is it a 3PH?
   / Used Backhoe search for B7200 #10
re:BH4672,
It's a probably "4 pt" mount.
Check with Messicks. I know they made one for the B7610, my dealer was going to get one for me if I went with the BH4672.
/edit - but isn't that hoe a little large for the B7200?
/edit - another link about broke back tractors http://www.tractorbynet.com/forums/buying-pricing-comparisons/32962-tractor-can-break-half.html
NEW Fork Extensions (A59000)
NEW Fork...
2014 CATERPILLAR 966K WHEEL LOADER (A52709)
2014 CATERPILLAR...
2016 PETERBILT 579 (A58214)
2016 PETERBILT 579...
2007 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A58017)
2007 INTERNATIONAL...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2002 International 9200i Truck (A56435)
2002 International...
