Motor oil for Kubota?
/ Motor oil for Kubota? #21
Any one else hear anything re CI vs CJ ????
Yep, all over the 'net. CJ-4 oils are formulated with lower amounts of zinc and phosphorous (and the ZDDP compound produced thereby) to protect catalytic converters and particulate filters in '07 and later engined vehicles using ULSD fuel, along with new and/or revised ratios of other additives.
If you've nothing to do for a few weeks, google "ZDDP" then settle back ..... :eek:
There was a lot of concern that the reduced ZDDP levels would cause valve-train wear problems in pre-'07 engines, but, based on quite a few million miles of OTR use, such does not appear to be the case. Diesel Power probably has access to some anecdotal evidence.
In any event, CI-4 sure won't hurt anything in pre-'07 stuff, or even post-'07 as long as there are no cats or filters, but I'll have no problems running CJ-4 once my stash of CI-4+ Rotella "T" 5-40 is used up. ;)
/ Motor oil for Kubota? #22
I'm new to this forum, so someone may have already addressed this in the past. I bought a Kubots L4240 last June (2008). The fifty-hour service light came on the other day, so I went by my local dealership to purchase the oil and filter I needed. I also bought a hydraulic filter. Talk about highway robbery!!! $105 and some change! The 2 1/2-gallon jug of "KUBOTA" oil was over $50, and the hydraulic filter was $37. NEVER AGAIN!!!!
What I'm wondering is, does anyone know of an "approved" oil that I can use in place of the Kubota oil? I've already found the correct Wix filter numbers for next time (at half the price). Now I need to find a motor oil that will suffice. I'm considering Delo 400 or Rotella. Any ideas??
I think there is more superstition, fear and plain nonsense believed and written about oils than (almost) any other subject.
Yeah, oil.
Oily oil will do.
There is little/nothing different or in any way special about the laws of physics inside a Kubota engine.
Metallurgy, engineering, also still apply.
That said; I get Rotella T at the local Mall_Wart
/ Motor oil for Kubota? #23
I'm the proud owner of a '95 L2900 Compact Utility Kubota Tractor (purchased new with a FD72 Land Pride grooming mower).
I used Kubota oil for the first two years, then went to Rotella-T Synthetic oil (blue bottle) for the last twelve years without issues. This tractor has not had the need to be repaired in any way, shape, or form. No issues, notta, nothing.....!!!
When I look back and remember this, I find it so hard to beleive.
Wilson
/ Motor oil for Kubota? #24
Can I switch from synthitic oil to conventional oil
/ Motor oil for Kubota? #25
Yes you can switch from synthetic to a conventional oil.
/ Motor oil for Kubota? #26
Good discussion fellas. I always like to read discussions on oils and each time I learn something. d1king, John Deere plus 50 oil is still ci4plus rated and unlikely to change seems like I get it for around $12 a gallon. Does fine in Kubotas too:D
Take care
TPS
/ Motor oil for Kubota? #27
Take care
TPS
If you want a good oil debate there are other better places. Jd oil is good for the $12 price so expect a $12 product.
/ Motor oil for Kubota? #28
Because it gets fairly cold here, and my Kubota B8200 is by nature a cold blooded beast when it comes to starting unless I have the block heater plugged in for 15 minutes, I have been using Rotella Syn 5-40w for several years- it's diesel rated, and only 19-20 bucks a gallon at Wally World, well worth it for me. I bought a bunch of Kubota filters from Tractorsmart or one of the other supply places mentioned on TBN, and they were about $6 each- again, well worth it for me. My biggest problem is not enough hours, maybe 40-50 a year, so I am "wasting" oil.
/ Motor oil for Kubota? #29
I agree but Amsoil 5w30 is more but a way better oil; and performs better in UOA. Plus no heater is needed here in northeast. :)
Kubota filters are overpriced. You can buy US made filters "out the door" for about $4 per filter. Heck, Wiz is the same quality and $3.XX each.
Not saying you are wrong but TS is cheap till you add in the S/H. Then Rotella is nice but for the price.....need to weight that.
/ Motor oil for Kubota? #30
SWo3,
So lets see the oil forum where people are talking about what oils they use and I mention JD plus 50 oil being a CI 4 plus and get called down on it for wanting to start an oil debate??!!!.. What the heck is that about? If you do not like JD oil then don't use it. Still the original question was for a good oil that won't break the bank and JD Plus 50 is just that.
TPS
2025 Pabreak Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak...
ATTENTION! PLEASE READ (A60463)
ATTENTION! PLEASE...
Mower King Brush Cutter (A53317)
Mower King Brush...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
