3320 Stability Woes
/ 3320 Stability Woes #1
bluemalibu
Butte Co, CA
I ordered my '08 last year with the 300cx FEL option to give me the flexibility of higher payloads and a more rugged unit, but have come to regret it... I have less than 30 hours on the machine and have had it on two tires three times now. I cannot believe just how much the extra beef of the cx unit has raised the center of gravity on this beast. It is downright spooky to operate. (The dealer was wide-eyed as he backed it off of the car trailer when delivering it... the pucker factor hit him as well)
All of our orchards are on rolling foothills so it doesn't help the situation.
I'm lugging around a 550lb box scraper now to help stabilize it... and am about to have the tires filled, but am wondering if that will make that much of a difference?
/ 3320 Stability Woes #2
Welcome:D
I think filling the tires will help a lot...also do a search on "spacers" to look at what others have done to widen the stance to improve stability.
/ 3320 Stability Woes #3
Definitely get the rear tire filled with liquid of your choice. It made a huge difference in stability on my tractors.
MarkV
/ 3320 Stability Woes #4
I'm lugging around a 550lb box scraper now to help stabilize it... and am about to have the tires filled, but am wondering if that will make that much of a difference?[/QUOTE]
You need to get a ballast box at a minimum. Loading the tires will help alot also! This tractor was not designed to be a loader without substantial weight on the rear. If you read the manual, it stated a filled ballast box and filled tires. This is about proper use and operation of the tractor....
If your dealer does not know this, he should have his dealership taken away....
/ 3320 Stability Woes #5
Any time that a FEL is installed, the tires must be loaded along with ballast weight or wheel wgts in place of loaded tires. in addition to traction and stability reasons, this also protects the front axle, which is designed to handle 15% of load when bucket is full, when improperly ballasted, the front end is handling upwards of 70 to 80% of weight load. Front axle not built for this.
/ 3320 Stability Woes #6
Also try turning the wheels inside out for better lateral stability. As long as there is no MMM there shouldn't be any clearance problems.
/ 3320 Stability Woes #7
I thought John Deere had a policy of not selling a Cut with a loader without a ballast box, was I wrong in this thinking?
/ 3320 Stability Woes #8
deere does a great job of specs and requirements for the dealer to follow, what it comes down to is dealerships bottom line to get the deal compromises the integrity of the tractor and the dealership. I will not do that, poor training on part of dealership to not convey to the consumer why these things are important to overall performance and cost. " what you pay is relevant to the value you receive "
/ 3320 Stability Woes #9
I hate to say this, but the 3000 series tractors stock from JD without spacers, etc. are inherantly unstable. Those that do not have problems with this aspect of the operation either have taken steps to stabilize the tractor with additional ballast or have added spacers or inverted wheels, or both. This is one reason I sold my 3720. I loved the tractor, though it was too large for my needs. It had good power but on my hills would raise rear tires easily and even tilt up on two wheels at times. This was with R4 tires filled to the brim with RimGuard and running either a ballast box or heavy rear implement. Due to the tightness of many of my work areas I could not substantially widen my rear stance without limiting access to these areas of my property. I would say ballast and ballast box and perhaps spacers will help this issue, but even then it will not totally solve it and one will still have to be mighty careful.
John M
/ 3320 Stability Woes #10
This info from the JD manual.
REQUIRED MINIMUM BALLAST FOR 3X20 SERIES AND 3203 TRACTORS
Ballast - Fluid-filled rear tires and 500 kg (1100 lb) of 3-Point hitch ballast and three rear wheel weights per wheel.
Ballast given is required with minimum rear tread setting.
A Ballast Box with Extension willl yield 1056Lbs when filled with concrete (JD Spec)
I have my rear wheels set to wide and leave the BH on most of the time and have no compliants regarding stability.
/ 3320 Stability Woes #11
Hi:
I had a 3320 Open and now have a 3720 cab (Read even tippier). If you ballast it properly and load the tires (or use wheel weights) it feels pretty stable compared to without it. I have an 1100lb ballast box that I use whenever I use the loader for anything substantial.
I also put 6" (6" per wheel, 12" overall) Unverferth wheel spacers on it. I'm now running 66" wide in the narrow position (I'd add about 5" for a little over 71" if I went to the wide position). I'm running that with R3's and it's pretty stable, certainly much more than when I first got it. When I first got it I had unloaded large R4's and with an 800lb stump grinder (long with extra leverage) it would still lift the rear end easily and I was up on 1 wheel once (Read super-duper pucker factor) when using the 72" grapple with a long tree that was heavier on one side.
/ 3320 Stability Woes #12
The argument for adding rear ballast cannot be overstated. However, I am concerned about the accuracy of saying that adding rear ballast reduces the stress on the front end. Unless the ballast is added considerably behind the rear wheels, the load on the front remains the same. The percentage front and rear of course changes, but that is only because of the rear change. There is no front change. If the rear of the tractor rises considerably, then of course there would be weight transfer to the front.
/ 3320 Stability Woes #13
Hi:
Will these spacers create additional stress on the rear axles? I know I am interested in the 3000 Series tractors and this issue is of concern to me. I also thought of going with the smaller size R4s to help lower COG...if that would even make a difference.
Thanks so much for all of the suggestions offered... and a big thank you to Rick for the in-depth PM help!
/ 3320 Stability Woes #15
I'm not an expert on that model, but yes it will. Anytime the acting force is moved outward from the supporting bearing, a moment, or twist occurs. The thing I don't know is if this would be anything to worry about on this model. Many are built so robustly that you can get away with the extra load.
/ 3320 Stability Woes #16
I have a 3320 and can't add much to the excellent advice above. I have all R4 tires turned out and filled and have a heavy 6' Gearmore box blade or 447 backhoe on the rear most of the time, and I am pleased with the performance on my very hilly terrain. The backhoe is most usefull when working on a side hill because I can extend the boom far out to the uphill side to insure good balance. Most of the times that I have had a rear tire lift is when carrying a heavy log with the loader/grapple that I grabbed off balance. Weight it down and go slow. Steve
/ 3320 Stability Woes #17
I solved my stability concerns with the install of a set of Turf specials. I have slopes on my property and they range from as steep as 15 - 25 degrees, and I have been on all of them. I also have a MMM, and I know that also helps. The Turf specials work, but I know when I installed my blade this year and put my dirt scoop on the back, my stability went way up, and the dirt scoop wasn't even filled with anything substantial (300 pounds of ice melt and salt). This year I will run my loader with the ballast box on and my MMM. I toyed with the idea of spacers (6 inchers from Unverferth), but sofar I have not yet bit on them. But who knows, I might in the future.
/ 3320 Stability Woes #18
I've got a 3320 and would only add that the tilt-meter accessory helps with my mental health - it really helps calibrate what feels tippy to where I might be relative to an actual tipping point. There's many ways that the little meter is wrong, but it's still been a useful reference point for me, especially when the machine was new.
I have hilly terrain with +15 slopes, R4s filled, usually a BH and grapple bucket, and I keep everything down low and go slow slow slow. I'm thinking about adding spacers and/or wheel weights this spring as well.
/ 3320 Stability Woes #19
As above, I never use the loader without weight. Backhoe in the summer and weight box in the winter. My tires are not filled. The reason I bought this machine was the size and the CX power. With only the weight box, I just picked up a small mead speedcat crawler and put it the back of a guys trailer. He looked at me when I chained/hung it from the bucket and said no way. In she went.
/ 3320 Stability Woes #20
Technically Yes, but also keep in mind that the max width with R1's is 68.4 (Very wide, wider than I am now at 66) so I'm not exceeding the designed or factory setup maximum width.
It's the outer edge of the tire (width) that counts. Now if I flipped the wheels with the spacers for 72" I'd be a little over but not by much.
Why they don't offer the 8 position wheels with R4's is beyond me. You only get 1.6" of width gain when flipping them (R4's) and I think they are not very wide in the wide position. The R3's offer 5" of difference narrow to wide. The R1's offer about 16" (52.4 - 68.4) narrow to wide. The big R4's offer only 1.6" (58.1 - 59.7" wide). The smaller R4's only go 57.3 - 58.9. Again, I'm not sure why they don't offer the 8 pos wheels with the R3's and R4's, would make things a lot easier. I don't hear many folks with R1's in the wide position complaining about stability.
One thing about going wide is you'll be wider than the 63" bucket and the 59" blower. I haven't found this to be an issue. The extra width very rarely is an issue and the stability it provides is well worth it.
The dealer put mine on and I didn't void my warranty or anything. Note that We also flipped the front wheels also.
One note also about filling tires. You may find that you like the 'stability' better but in my opinion (I rode with empty/full tires on my 3320 and 3720 - Filled now) filling them does make the ride quality (shock absorption) crappier. It makes sense since due to the reduced air volume (say 90% less) any distortion in the tire raises the pressure x times (10 times in this case) faster. I.E. With a non-loaded tire running 20psi conforming over a rock reducing the volume by 5% only causes a 5% increase in pressure, but if the volume (air, liquid doesn't compress) was reduced by 10 times that now would be a 50% increase in pressure. Translated = It'll ride harder over obstacles and bumps.
2019 CATERPILLAR 299D2 SKID STEER (A65056)
2019 CATERPILLAR...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
2012 FORD F250 EXTENDED CAB PICKUP TRUCK (A66091)
2012 FORD F250...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
2015 Ford Explorer AWD SUV (A66738)
2015 Ford Explorer...
Unused HLA HD42 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused HLA HD42...
