Engine Air Compressor?
/ Engine Air Compressor? #1
BrentD
I saw a brief mention in another thread about using a 3-cylinder engine as an air compressor. My mind was already headed along that route when I came across the reference so I guess I'm not the first one to come up with the idea, but I think I'd like to run my version of the idea by you guys to see if my plan is sound.
My current plan is to find an engine from a Geo Metro. Those engines were either 1.0L 3-cylinder or 1.3L 4-Cylinder engines depending on the model (LS or LSI). I'd strip all the electronics and exhaust off the engine and seal up each exhaust port individually to isolate the cylinders from each other. I'd remove the spark plugs and thread pipe into the spark plug ports. The pipe from each plug port would thread into a Y of some sort that would have 2 check valves in opposition to each other. The check valve that would allow air to flow back into the cylinder would then be routed back to the intake and the other check valve would be routed to some sort of manifold that would gather the compressed air from all three cylinders and route it to the holding tank. That arrangement of check valves would convert the exhaust stroke into an additional compression stroke doubling the engines efficiency as a compressor.
The engine flywheel would be removed and replaced with a pulley to allow the engine to be driven from an electric motor.
The questions I have would be how large of an electric motor would be required? I've got a couple of motors laying around from swimming pool pumps that are rated 1HP @ either 1800 RPM or 3600 RPM. Can't remember which at the moment. I'm thinking of using at least a 2:1 reduction between the electric motor and the engine to raise the torque at the engine's crankshaft.
The next question would be how many cubic feet per minute could I expect from this arrangement assuming a 1.0L displacement running at 900 RPM? If I'm looking at the info on Wikipedia correctly then the displacement is based on the total air moved through an engine during one complete 4-stroke cycle which would comprise 2 complete rotations of the crankshaft (At least for a 4-cylinder engine). If that is correct then my check valve manifold would actually double the engine displacement making it 1L per rotation. 1L = .035cf so at 900 RPM I would be getting close to 30cfm. Does that sound right?
I've done a compression test on my Geo Tracker's engine and get between 150 and 170 psi on each cylinder. Would it be reasonable to expect a compressor like this to produce a working pressure in that same range?
Would that mean I'd end up with a compressor that could produce close to 30CFM at 150 PSI or would the compression ratio of the engine need to be taken into account in calculating the cfm?
/ Engine Air Compressor? #2
Mobile tire service trucks used 4 cyl engines for compressors by using the two center
cyls for air and the other two for the motor to run on. This works very well. The exhaust valves on what would be 2 & 3 of a 4cyl are altered so the valve won't open but the push rod will hold the lifter in to maintain oil pressure. The spark plugs are removed and each plug hole has a one way valve in the pipe going to the tank. The spark wire are grounded. This makes the engine run rather smoothly.
I have seen 302 ford engines fixed using one side side to run on and one side for the compressor.
Mike Burts
/ Engine Air Compressor? #4
Note when using a gas combustion engine as an air compressor that the compression ratio is quite different. A typical gas engine is about 9-10:1 while a compressor is essentially infinite:1. This means that you are probably limited to about 125psi. Good for nearly all applications of air tools, but if you are looking for 2-stage performance (175psi) its not there.
The Volks compressor thing looks pretty cool.
/ Engine Air Compressor? #5
A one horsepower motor wouldn't begin to turn something like that......
/ Engine Air Compressor? #6
It might just be cheaper/easier/more utilitarian and a whole lot simpler to just buy a compressor head that meets your specifications. :D
/ Engine Air Compressor? #7
International/Farmall had a tire inflation kit where you removed a spark plug and hooked a hose in to the plug hole. The compression from the cylinder with the engine running would allow you to inflate tires on your tractor or any ting else. I knew an old grave digger that had a 4 cylinder Wisconsin engine where two of the cylinders were an air compressor that would run his jack hammer for frozen ground.
Your idea is proven you just need to get it done.
Dan
/ Engine Air Compressor? #8
Gee Dan, That's exactly what we did back in the late 50's, when I was 10-12! I was so glad to be able to drive the farm tractor that the gasoline/air mixture in the tires was of little concern!
That first part about the infinite compression ratio doesn't seem quite right. Any given cylinder is going to have some sort of compression ratio that is calculated by comparing the volume of the cylinder with the piston completely retracted to the volume left at the top of the cylinder when the piston is at full stroke. An air compressor cylinder might have a better ratio than an engine if it has a flat head and recessed valves. The psi any given cylinder/piston mechanism can generate will be limited by compression ratio, quality of valve seals, piston ring seals, and the amount of stress individual components can handle. (In an application like I'm planning, the main limiters are going to be the electric motor and the various seals. If I wanted a higher compression ratio I could switch to a diesel engine for the compressor instead of the gas.
As far as the PSI goes, As long as I can approach 100PSI at enough cfm to drive a sandblaster I'll be satisfied. My sandblaster is about the biggest air hog I have at the moment, and can't really think of anything else I'd ever get that would need more.
The only stock air compressors I've been able to find that come close to the CFM rates of an engine are between $700 and $1000. I can pick up a used running 3-cylinder geo metro engine for around $100 (Heck, a friend of mine once bought an entire running geo metro in good running condition for $25). The biggest cost would be the electric motor if my 1hp pool pump motors won't drive it. Of course, I could always just pick up a second Geo engine and have one drive the other....
/ Engine Air Compressor? #10
The original engine compression ratio matters not. It will all be based on the volume the piston displaces on each stroke.
How will you cool it?
Check out some package compressor units for volume and pressure vs electric motor size. That should give you a good idea on how much your one horsepower electric can attain.
Why the two check valves. With the exhaust valve locked closed just one check on the spark plug exhaust should do the job if you go that route.
Note: removing the intake valves and placing a check valve on each cylinder intake would probably work much better. That would get rid of the valve train.
You could also forget about the spark plug exhaust and use a check valve on each isolated exhaust valve port. Larger port size that way for better fluid flow.
Still working that part out, although I suppose I could leave the original water pump intact and continue to use the original cooling system.
I was planning on retaining at least the intake valves to avoid having to fab up a check valve adapter for each intake port, although that is another possibility. I'm just trying to get by with as many off-the-shelf parts as possible. That was part of my reasoning behind the second check valve. In a 4-stroke engine, the intake and exhaust valves are both closed during the power stroke to allow the expanding gas from the burning fuel to force the piston down. The power stroke would be irrelevant in a compressor application so I would need to either find a way to force the intake valve to open on every down stroke, or use an additional check valve to allow the sparkplug port pipe to function as an additional intake for the power stroke.
One option for changing the valve operation would be to replace the camshaft sprocket with a duplicate of the crankshaft cog. Normally there would be a 2:1 ratio between the size of those two pulleys to make the camshaft rotate once for every 2 rotations of the crankshaft. If I made the timing cogs 1:1 and removed the exhaust rockers I could do away with one set of check valves.
/ Engine Air Compressor? #12
My grand father had 2 of these units on was a 6 cylinder and the other a Willys 4 cylinder that the 2 insides ran the six rand off the 3 front ones and rand air of the 3 back the yburnt in his shop when I was a pup. I know the son of an old MM dealer that has a flathead Ford that 2 inside pistons on one bank pup and the 2 outside ones on the other pump. Shramm sp made several tractors using Farmall and Fordson, and Ford tractors that did this to run Jackhammers My nieghbor that had an old asphault company had one they used to use It was a Farmall based tractor had squared sheet metal. They used it alot then parked it for about 25 years I tried several times to buy it with the old man saying hed get to using it again then scrap went up and it rode a boat to china. Ive seen several old pictures of Schramm loader tractors with buckets to remove and load the chunks, They had several backhoes like this to that had a hammer that could be put on the end for an old time hoe ram. I also saw a man use a V8 with a plastic plate epoxied in the intake seperating the banks with a 2 barrel or one barrel carb mounted on one side and and air filter o nthe other side. He did something with some of the push rods I think reoved them on the air side. It ran very good infact he had enough CFM to run a large pot type blaster repainting boat hulls.
/ Engine Air Compressor? #14
Brent,
Not quibble on the compression ratio thing, but the piston in an air compressor is flat top and strokes all the way to the top of the cylinder leaving no appreciable air volume. The valves are just spring loaded check valves seated right against the face of the head and only the intake valve extends into the cylinder during the intake stroke. Nonetheless, this is just an interesting technical detail often overlooked.
/ Engine Air Compressor? #15
OK, with your two checks off the spark plug why not just keep the intake and exhaust valves closed permanently. Eliminates the valve train and keeps it simple.:D
That's what I was going to say. Just take out your rocker arms completely and run a check valve off of each spark plug hole. Now you've got air volume from each stroke, and you don't have to worry about all the added fabrication. Run the tubing from each cylinder to a cross pipe fitting and run the fourth side of the cross to your tank.
You're going to need a lot of power to run this thing, though. 30 CFM at 100 PSI no matter how you do it is going to take a lot of power.
For cooling, what would be the problem of just leaving the existing cooling system in tact? Your engine is going to be turning, you should be able to keep the water pump working and just run the radiator and cooling system like you normally would. If you went the two engines option, you could also run coolant from the powering engine through the pumping engine, and then back through the powering engine.
/ Engine Air Compressor? #17
Have you considered a PTO aircompressor?
What kind of work do you do that requires 30 cfm.?
/ Engine Air Compressor? #18
I was thinking of popping a PTO shaft on my old converted York A/C compressor today. I needed to seat some beads on an old car far from air. After the 3rd trip with the pig I was getting a bit tired of it.
Ended up dragging the car with flat tires and rolling them off the rims while dragging.
Ken
/ Engine Air Compressor? #19
Ken
Just a friendly suggestion... Next time you might consider taking the tires off and hauling them to the air instead of the whole car.
/ Engine Air Compressor? #20
Ok, mabye I dont understand all I know about whats trying to be done (that has happened in the past). But aren't you going to need at least the intake valve functional to let air in the chamber to be compressed?
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 1HTMMAAL0DH414751 (A61165)
INOP/NON-RUNNING...
Toyota Pallet Jack (A61166)
Toyota Pallet Jack...
2014 Nissan Altima Sedan (A61569)
2014 Nissan Altima...
20ft Shipping Container (A61166)
20ft Shipping...
New/Unused Wolverine Quick Attach Auger (A61166)
New/Unused...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
