Hydro pedals
/ Hydro pedals #1
hoogy
Member
Chester, Vermont
MF GC2310 HST
I just recently purchased a MF 23hp tractor. Was wondering if you can take the hydro foot pedal. and have it made to side by side forward and reverse instead of the current toe and heal pedal
/ Hydro pedals #2
All it takes is money....
Find a custom fabrication shop and open your wallet. It's probably a 20 - 40 hour job to re-engineer the linkages, fab up the two peddles and install. A quality shop will charge 90-125 per hour for that type of service, so figure on 2-5,000 to have a pro shop custom out your tractor.
jb
/ Hydro pedals #4
WOW That much. you wouldn't think so
I'm guessing that either you have never had or done anything like this before. My guess would be in the 4-6k range. Anytime that you do one offs,(one of a kind, starting from scratch) the end product is BIG bucks, if it is done right.
Give the rocker foot pedal a chance, you might even like it in just a short time. I would give it a chance before paying to get new control pedals made.
/ Hydro pedals #5
Anybody that don't like a rocker foot pedal just don't know how to apreciate them.
Either that or they haven't learned how to hate 2 pedals.
/ Hydro pedals #6
Just go visit the John Deere dealer, they have EXACTLY what you are looking for:D
/ Hydro pedals #7
I find that I can find enough work to do that I don't need more linkage to maintain and lube or adjust when it might get bent from a tree limb or debris that the tractor might be going over.
Sorry but the system you have is the number one system used by far and it's with good reason.
/ Hydro pedals #8
Ummmm ..... actually I would!:D
Maybe you wouldn't:p
Sticker shock is why there are not more full on custom cars, trucks and tractors out there. Now you could find some shade tree type with a 3 pound maul and a welder that can do it for less. But, what happens when the linkage binds up tight and you're going full speed toward the road? Think that guy with the 2 day old beard, greasy coveralls and halitosis is going to pay for your funeral expenses? Ha! That's why he made you pay cash - no trace no liability.
jb
/ Hydro pedals #9
If you do not want to spend the big bucks; do it yourself. Begin with a "simple" sketch of what will be needed, to the best of your ability. Then call around for prices on the items needed, then call a machine shop and explain, to the best of your ability, what you will need made and see what kind of price he gives you. You see where this is going. Hopefully you can use a cad program to finally draw an exact blueprint of what you want. I am positve it will all fit together exactly as you planned on the first attempt because I am sure you have better luck than myself.
It willbe cheaper to trade your unit for a machine ( new holland, JD etc) with what you are looking for.
/ Hydro pedals #10
*Sorry but the system you have is the number one system used by far and it's with good reason.
* Rite ON = Like I said .
/ Hydro pedals #11
Never heard this debate before, I've had both and prefer the 2 pedal. Don't think I'd pay thousand$ to change them though, I would learn to accept it the way it is.
Rather have my foot resting on a solid platform than a rocking pedal, had an old Bolens that didn't have a foot rest at all, just an over sized rocker pedal/rest. That took some getting use to!
JB.
/ Hydro pedals #12
JB.
Interesting. I nearly NEVER have my whole foot on the rocker. I have my toe on the forward part and the heal on the deck for forward jobs. I have my heal on the back part and my toes on the deck for reverse jobs. Nice and comfortable that way and I have size 11-1/2 boots too.
On some VERY short forward backward loader jobs I have used the whole foot on the rocker, but that is rare.
Maybe likes and dislikes are also shaded by operator technique?
jb
/ Hydro pedals #13
I've got one of each kind, and I find the rocker (front pedal goes forward, rear pedal goes backward) to be more intuitively obvious to me, i.e., I'm less likely to hit the wrong pedal. That being said, the Kubota with the rocker (really two pedals connected to a rocker under the operator deck) was my first tractor, and the JD with two pedals side-by-side is new.
/ Hydro pedals #14
All of the Power-Tracs have the left/right setup. Left foot rev, and right foot fwd, or were you talking about the left/right pedal on the same side?
/ Hydro pedals #15
Deere uses two pedals side-by-side under the right foot. Left pedal forward, right pedal reverse.
/ Hydro pedals #16
My buddy has foot damage and can't rock backwards to engage reverse.
Welded a 1/2" pipe union and he screws in a lenght so that he hand operates the fwd/rev.
Works for him.
/ Hydro pedals #17
If this is a 1500 series (1523??) you may can find the parts you need from MF. I don't know about the smaller 1500's, but the 1533, 1547 and 1552 at least have changed to a side by side pedal arrangement.
The parts to change (if they will even fit) might be expensive, but I don't think they would be as much as quoted here for a one off fab job. Another consideration would be the holes in the floorboard would be in different places, but that is what the torch or plasma cutter is for:D
I don't want to add fuel to a smoldering fire, but I have to agree with hoogy on preferring the side by side pedals. Other brands may have a better layout, (and I have not tried any others) but the Massey rocker pedals seemed awkward to me (on a test drive only, haven't worked with one). Forward is fine, reverse was hard to get my heal on. I agree the rocker makes more sense.
jp
/ Hydro pedals #18
The Rocker is causing or inflamed my foot to the point where I haven't been able to use my BX23 for over 6 weeks.
Turns out I have a heel spur that I never knew I had or that ever gave me any problems... I never had any foot issues what so ever until I spent about 20 hours moving dirt over the course of 3 days...
The Rocker just happens to hit my heel spur when I press down to go in reverse...
/ Hydro pedals
THe reason i was asking Was i have arthritus in my right hip. As hurts to move hip up and down. Going for hip relacement in the spring i hope. I do like the idea of the pipe.
What is this modification it would be a hand lever, similar to the JD 316 . Thanks hoogy
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A61165)
INOP/NON-RUNNING...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
Echo SRM2620 Gas Trimmer (A60352)
Echo SRM2620 Gas...
