kubota glow plug indicator not glowing/hard cold start
/ kubota glow plug indicator not glowing/hard cold start #11
For some reason when i preheat, it dosn't glow but the glow plugs get warm but in no way hot as they should be, first i thought the connections so i cleaned all of them and same problem, the little coil does not glow even if i preheat for 40 seconds, it still takes about 3 tries to start the thing, i know its below freezing but i can't remember it ever being this hard. my fear is that the glow plugs are damaged (previous owner used starting fluid...ALOT), my other thought was the coil could need replacing. but these are just ideas, thanks for any help
Is this machine new to you, and have you ever started it under the current conditions and had it do other than what it is doing now? How are you determining the glow plugs are warm, not hot? There is no way to tell with the plugs in the engine, as the head sinks all of the heat they produce before you could feel it on the plug body with your fingers, if that is what you are doing.
It is not that uncommon to not be able to see an indicator coil glow in the daytime, even though it is conducting. You could try a new one and see if that helps. The old one may have aged enough that it does not conduct as well as it should.
Glow plugs on engines with indicator coils are usually wired so that the plugs are in parallel with each other, but in series with the indicator coil. The only failed component other that the switch that would result in no glow plug activity at all would be the indicator coil. However, I have seen one Kubota wiring diagram that showed the plugs in series with each other, a resistor, and the coil. That kind of lash up would result in no glow plug activity if any of the components failed.
As has already been posted, glow plugs almost never fail. Difficult starting in below freezing weather is not all that unusual for diesels, especially if their compression is down a little bit. That may be what is going on.
i just put my finger on the first one and found it extremely hot and the other three nothing really at all, i just figured that ment they were not getting hot, i have had the machine for about 7 years and never had a problem like this even in colder weather it always fired right up first try, i like the idea of disconnecting the wires and checking for resistance like PILOON said and if that fails ill take them out and mabe try hooking them to a battery
i think i will have to buy a better multimeter though mine only has 1k ohm for resistance setting all the rest are volt settings
/ kubota glow plug indicator not glowing/hard cold start #14
Out of curiosity, I tried that on my Branson and could not tell any difference between power on and off. The machine had not been run all day, at the time.
I wonder if you have one with a short. That would be extremely rare, but it might account for what you are seeing, although I certainly would expect the indicator coil to glow under those circumstances.
Be careful about hooking them directly to a battery. The indicator coil acts as a resistor. Without it in the circuit, you might burn one out. If you do hook one directly to a battery, do it very briefly.
Im with you on that one Snow, i was reading about that acting as a resistor and some people say 8 or so seconds maximum but with those close clearences i dont want to take any chances, i just might end up taking them to get checked at the kubota dealer if im still in confusion the next few days but i think im going to have to take them out no matter what wich is easy for the first 3 plugs but the last one is right behind the injector pump area and all of the steel lines
/ kubota glow plug indicator not glowing/hard cold start #16
The glow plugs AND the indicator are all 'in parallel'.
One side is positive and other ground, the engine being the ground.
That being said, one side of the indicator is ground and the other positive.
In that way the plugs AND the indicator all heat (glow) at the same time.
(glow plugs, get it!)
The indicator is sort of 'an out of body' glow plug.
In parallel circuit they all get the same voltage at the same time and if one is burnt the others still work.
Series, one goes, none 'glow'!
Glow plugs being high amperage devices by nature are more suseptable to bad connections, so clean all contacts.
/ kubota glow plug indicator not glowing/hard cold start #17
quickest and easiest way to check is to whip them out connect up to a battery for no more than 5 secs they should glow red hot in that time if not get new ones we commonly find over here that once one is gone that the rest are not far behind YES they do burn out they work on a dead short so they do have a limited life, please be careful doing this though as i have seen holes burnt in batteries :(
/ kubota glow plug indicator not glowing/hard cold start #18
I checked mine by taking them out and using the wire that goes to the first one and then grounding the plug to the block turned the key and turned the switch to glow and it turned red. Did the same to the others. They all got red hot so I put them back. But my Kubota still starts hard so now I'm thinking I'll check the valve gap. If the valve gap is too big and the valves aren't opening long enough won't it effect the compression? I don't have a compression Gage or I'd check it. Maybe that's our problem.
I also was thinking about compression but i always just thought that if it didnt smoke when running i was fine (just a very rough estimate), during any warmer seasons it starts up just fine its just this cold weather it does it in, but i have some good news about the glow plug prices, i went down to the local autoparts store and i can buy plugs there for $13,95 each so obviously the dealer price at almost $60 each was typical dealer prices, or i was quoted for actual kubota brand plugs but i doubt they make there own
/ kubota glow plug indicator not glowing/hard cold start #20
Mine is the same way. When it is warm it starts right up, now that is is cold it starts really hard. Bought a new battery,new air filter put synthetic oil, glow plugs work good. I haven't found the problem yet. If the valves are ok the next is going to be a compression test. I suppose if all cylinders had low compression it could run and it would run smooth it would just be hard to get going.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
light tower (A60352)
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
