My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum
   / My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum #1
Sylvainl
Laurentide (north of Montreal) P.Quebec
JD 4720
with a Google search I found out it can only lift 1600 pounds, any one else as track for winter used...
   / My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum #2
The JD brochure says the 4x20 series will lift 2500 lbs 24" behind the link arms. Where did you read the 1600 lb lift?
   / My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum #3
Depends on the loader:
I have a 400cx on mine and have picked up 2700 lb concrete culvert. look back through my post for pix.
If I have the 4 in one on I have a payload of around 2000.
   / My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum #4
If you referring to the FEL lift capacity, the 400x is 2,368 lbs at pivot pin (max ht.) and 1742 lbs 500mm ahead of the pivot pin.
   / My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum #5
I can't help but to ask about your machine on tracks...Do you have any more pictures? How do they perform?
They look pretty awesome!
   / My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum #6
I just off loaded a ton (1 Pallet) of wood pellets from my Dodge 2500 Diesel bed with my JD 4320 with 400CX and Frontier pallet forks just fine. Only had my Champion wood chipper on the back so was a bit light vs having my 448 on the rear. (plus loaded tires) But moved them down from the barn to the garage - 1/4 mile away up hills and down hills just fine.
   / My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum #7
Tractor wheels sometimes skid on ice when blowing heavy snow drifts so I thought about using those tracks but unfortunately found they are not legal for road use here :(
   / My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum #8
Why aren't they legal for road use?
   / My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum #9
I know many manufacturers do it, but lift ratings at pivot pin are useless to me and rather deceptive.
   / My 4720 couldn't lift 2000Lbs that's how I discover this most interesting forum #10
I agree on the pivot-pin stats. It just adds some more "numbers" to the mix; and doesn't really tell you, anything...
Maybe; just maybe - there's somebody out there lookin' for a tractor that they need to hang rocks or logs off the pivot points... :confused:
AKfish
UNUSED 3 STEP - STEP LADDER (A54757)
UNUSED 3 STEP -...
2018 John Deere 470G LC Hydraulic Excavator (A55787)
2018 John Deere...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2013 Chevy Silverado 2500 HD (A55218)
2013 Chevy...
