4720 Cab Tractor Slow to Warm UP
   / 4720 Cab Tractor Slow to Warm UP #1
TCowner
SE Minnesota
John Deere 4720 Cab
I've had my 4720 with the factory cab almost a year now and it seemed like it took a long time to warm the cab to a comfortable level. It was about 20 degrees last night and it was nearly 20 minutes before I had reasonably warm air coming from the heat ducts.
Last winter it was much colder and the warm up time seemed much faster. I don't know if it might be a problem with the thermostat because the coolant temp guage seemed to take forever to move and it never got beyond about a third of the way into the normal range.
I just had the factory radio/CD player replaced and the roof has to be removed so I was thinking it might be the famous sealing issue that has been discussed here before.
Just curious, for those of you with the 4000 cab tractors where does your temp guage run say after about 15 minutes? Under normal conditions mine runs just a tad over the half way point on the guage. It was well under that last night and I was operating for about 45 minutes so I'm thinking its a thermostat issue.
   / 4720 Cab Tractor Slow to Warm UP #2
Do you have an engine block heater? They're a good way of having heat in your cab right away. Just plug it in 30 minutes to an hour before you want to startup.
Ralph
   / 4720 Cab Tractor Slow to Warm UP #3
This is the first winter with my 3520 Cab and I noticed the same thing...I cut a piece of cardboard approx half the height of the radiator and the full width and slid it between the Radiator and the Trans Cooler/AC Condenser...been fine ever since. It still doesnt even get to the the normal "Half Way Mark" on the temp gague, it sits at about 3/8's on the gauge with the cardboard..but thats enough for the heater to blow very hot air.
Called the dealership and they said they reccomend & do the same thing. Between the Heater cooling the water and the radiator, these tractors have TOO Much cooling power....with the heat completely off in the cab, it does warm the water much sooner...
Ralph, I have the block heater and had it plugged in about 2 hours.
Dave, thanks for the tip. I have a call in for the service manager because it doesn't seem to get as warm as last January when it was 15 below. So it seems that something has changed. However, the idea of the cardboard makes sense.
Terry,
   / 4720 Cab Tractor Slow to Warm UP #5
Terry, it usually takes at least 15 minutes working fairley hard for my 3520 to start throwing good heat. If your not getting the heat you did last year, they probably compromised your roof seal when they did the radio install. Now cold air is coming in affecting the heat output.You might want to check your cab filter to make sure its clean.
Sincerely, Dirt
   / 4720 Cab Tractor Slow to Warm UP #6
Based upon experience, I'd definitely check the roof seals before doing much else. Mine were damaged when the radio was installed by dealer and resulted in anemic heater and AC operation. Once seals were fixed, heater and AC worked great.
I spoke with my JD service rep on Friday regarding the slow warmup issue. The tech who replaced the radio, which requires removing the roof, is quite confident the seal wasn't damaged and that is went back into place as it should. He is leaning more toward a malfunctioning thermostat.
I tried what was suggested of putting a piece of cardboard between the oil cooler and the radiator to limit air flow through the radiator and that didn't seem to make any difference. The coolant gauge only moves up about 1/3 of the way and this is well below normal operating temperature.
About three weeks ago I was splitting wood and forgot to turn down the heater control when I got out of the cab and when I got back in I swear it was like an oven inside the cab. Granted it was about 50 degrees outside but today's temp of 20 shouldn't make that much difference. I deliberatly ran the rpm up about 2200 for a half an hour today and still the gauge only goes up 1/3. All summer and fall the gauge runs just slightly above 1/2 once warmed up.
It seems that properly operating thermostat would regulate the coolant temperature regardless of the outside temperature. My Ford F150's temp gauge runs in exactly the some position, once warmed up, whether its 80 above or 20 below.
But before I drive my JD service rep crazy I would like to know what other 4000 Cab owners are experiencing. After operating for say 20 minutes, then 30 minutes, where is the needle on your temp gauge? I need some others experience to compare to. I'm not satisfied with the performance. There just has to be something wrong here. Last January you couldn't wipe the grin off my face every time I plowed snow, or went to the neighbors for coffee. There is deep sadness now that can only be corrected with a properly functioning heater.
   / 4720 Cab Tractor Slow to Warm UP #8
From everything you've described - sure sounds like the thermostat is stuck open and the tractor is not coming up to normal operating temps.
Still on warranty? If so, when the dealer checks it out - have them run you thru a check of the cab seals as well to make sure you're "warm and fuzzy".
Best of luck.
AKfish
AK, the tractor is still under warranty and the service guys are great. I'm confident they will get it figured out. But at nearly $7000 for the Comfortguard cab it has to be right.
Before I traded for the 4720 I had a New Holland TC40DA with the Curtis cab and 15,000 btu heater. On a day like today even with all of the cold air leaking in around the seat, hydraulic controls, etc. it would warm up to a fairly comfortable temperature. The JD was a little warmer today but not that much so something must be wrong.
I still would like to hear from some northern folks whre they have their temp gauges running on the colder days.
   / 4720 Cab Tractor Slow to Warm UP #10
I would have them recheck the seal in the air box over the cab. I had a problem with my JD 3720 cab. Yes, it could be the thermostat but it would seem a bit unlikely in a tractor that new. I went through a new thermostat with higher setting than standard and multiple trips to 2 different dealers, talks with the area JD rep, JD technical help etc. Finally, a leak was discovered in the air box. I didn't start noticing the problem until the temps were in the 30's. An easy way to check if it is the air box, is to clamp the water hose leading to the cab on a cold day. If the engine heats up quickly with the hose clamped but cools again after removing the clamp, you have a problem with an air box leak. A leak pulls too much cold air into the air box and cools the air out of the heater as well as cooling the entire tractor water system. Do a search on "Poor cab heat" to hear the entire story.
The dealer installing a new radio, also makes the possibility of a leak very high IMHO.
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55302)
2011 New Holland...
2005 Ford F-650 2,000 Gallon Water Truck (A55788)
2005 Ford F-650...
DIXIE CHOPPER BLACK HAWK HP ZERO TURN MOWER (A54757)
DIXIE CHOPPER...
UNUSED JCT 84" HYD GRAPPLE BUCKET (A54757)
UNUSED JCT 84" HYD...
