Backhoe 18" bucket on BX24 backhoe?
   / 18" bucket on BX24 backhoe? #11
looks like it will work great for moving more material.
it works excellent!!!! only issue is you have to curl the bucket then bring the furthest boom into the main boom.
I tried to upload the vid but its larger than photobucket will allow:mad:
pics:
   / 18" bucket on BX24 backhoe? #14
That looks nice. Tucks up real tight. Where did you get the bushings, or do you lathe them out yourself?
This isn't BX experience, but on my Ford hoe, I went from a 12" bucket (2.5 cuft) to a 36" bucket that holds 10 cuft level and 12-13-14 heaped. It has lots of digging power, but when swinging and fully extending to dump, the tractor can get tippy. But that's 1500-1800 pounds out 13' from the wheels at 90 degrees. Still, the concept should transfer. The extra weight could be "upsetting".
jb
Thanks John!! I turned the bushings myself since the bushing downsizes to the new pins and also acts as a spacer for the boom.
So far it does great, Your right about the weight transfer but the BX doesnt have enough reach to really offset the weight. I could see a issue if you were on a hill but so far flat ground its great.
bump for those searching
   / 18" bucket on BX24 backhoe? #17
Hey IC very nice work!! I'm in similar circumstance right now. The problem is that i don't have the means to machine those bushings. Is there any place that sells them. I need 1 1/4" center pin hole, 2 3/4 outside diameter 3/4 length. Do you know of any place that sells them or is machining them my only option. Thanks.
Thanks!!
Any local fabrication shop or someone with a lathe can turn those down for you no problem.
   / 18" bucket on BX24 backhoe? #19
I have a BX24 and does not seem like it would have enough power with that size of bucket to dig. Maybe my Hydraulic pump is getting weak?
reed52
Reed, you cant hog into hard blue clay but Im around 1400 hours on my BX24 and it still handles the 18" just like it did day one. Majority of running the 18" is just how you operate the backhoe.
Ian
pressure washer, and trailer (A56859)
pressure washer...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2016 Chevrolet Tahoe (A55973)
2016 Chevrolet...
