3-Point Hitch Ford 6640 3pt hitch problem
   / Ford 6640 3pt hitch problem
Thanks again Rick
I was able to get fittings at local Hydraulic hose repair you were right metric straight thread with an oring. Checked pressure of main pump at Test port (Trailer brake Port) it was only approx 50 psi couldn't really tell exactly on 5000psi guage, but when I operated the loader it jumped to 650 psi and when I dead headed the loader or any of the remotes it jumped to 2600 psi. I pulled the main relief valve to the right of the filter on the pump to check it but it is all one piece. Iit seems to be closed I tried forcing air thru it and it doesn't open. I seems that the Auxilary pump is working fine and the problem is with the main pump or a relief valve for the main pump. Could the priority valve pack be causing this problem? The other thing that puzzles me is why won't the hitch lift if I dead head a remote this is giving me 2600 at the test port on the pump?? Shouldn't it flow through to the hitch? That was one of the tests in the book that I tried and it doesn't lift the hitch. Any other ideas??
Jack
While Cleaning up I realized the approx 2 gals of hydraulic oil I lost while pulling the pressure relief valve appeared to be possibly burnt or extremely dirty and dark in color with some type of silvery film running through it.
   / Ford 6640 3pt hitch problem #12
Thanks again Rick
Jack
I am not a whiz on these systems; I deal with them when I have to, but it's not enough to get really good at it. From all you tell me now, I would shift the focus from the rear pump to the priority pack. Pull it off, disassemble it checking for stuck valving, scoring, and plugged screens. You MAY also be able to identify the port feeding the hitch valve and air test that with the priority pack off the tractor.
Thanks for the help Rick.
I have to work next two days so I won't get to that until Monday unless I get real ambitious Sat or Sunday Night
Jack
Hi Rick
I took out the Priority Pack as you advised and found the check valve spring in the remote valve feed line broken. I ordered a new spring and all orings to put it back together. I checked all the spool valves and they appear to be ok. I found no bad grooves or scratches on any of the spools or sockets. I'm planning on draining the oil and replacing the filters also. Is there anything else I should look at while I'm in this far? It took a while as it seemed everything was frozen. Parts should be here Thursday.
Thanks again
Jack
   / Ford 6640 3pt hitch problem #15
It may well be that you have found the problem. Let's hope so! The silverish residue in the oil makes me think you are loosing a hydraulic pump (aluminum), but until you have noticeable pressure or flow problems. I'd not be too concerned.
Should I see if I can get my hands on a flow meter (Probably have to buy one) to check the pump flow out or just wait until I put it back together to see what happens with pressure and whether hitch works?
   / Ford 6640 3pt hitch problem #17
I think I would at least button it up and see what happened.
Glad you found the problem in the PP. I had a similar hyd problem at a remote that was a casting defect and was not fixable.. .. err.. it was fixable by replacing parts!
soundugy
   / Ford 6640 3pt hitch problem #18
At this point, I'd put it back together and see how it works. If you can get hitch function and some remote flow to either the rear remotes or the loader valve (if you have a separate loader valve) simultaneously, then you are getting flow from both pumps. Loader speed, for instance, should be about 1/2 as fast with the hitch moving as when it is not.
   / Ford 6640 3pt hitch problem #19
Be sure you have not moved the ASC lever that is at the front right hand corner under the seat----just a little movement will cause the oil to be diverted to the remotes and cut off the oil to the hydraulic cylinder--- just like on the 5000--that black round knob on the right hand side of the lift top----there is a ball and spring that holds that valve in the selected place---when you start to shell a pump----particles get hung up in the valve and slowly cause the priority valve pack to stick one valve at the time!!! The long end of the lever should be pointing at about 3 o'clock--find the picture in Part 8 Chapter 2 page 47 of the 6640 service book---if it got move a little bit the lift will not lift!!!!!
No luck. I replaced the broken check valve spring in the remote valve feed line and all the orings on the priority valve. I checked all the spools and they all move freely and there appears to be no grooves or scratches in any of them. I was carefull to put everything back as the book instructed. The pressure came up to about 50 psi and the hitch still doesn't work. The draft control lever seems to work easier though. Deadheading the remotes or loader gives me about 2600 psi on the guage and still doesn't move the hitch. The guage is still connected to the test plug on the main pump (Trailer brake Port). I double checked for an ASC Valve and there is none only a plastic plug on the floor and a pressed in plug on the side of the case. Any other Ideas Rick?? I got prices for a pump that range from online $600 to $1800 from NH. Is there a way to isolate the pump and just check it?? Or do you think I need to get into the rear case? Do I need to order a flow meter or should the pressure guages be enough?
2019 Peterbilt 520 Trash Truck (A55973)
2019 Peterbilt 520...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2007 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2007 Chevrolet...
2013 Chevrolet Express 3500 Passenger Van (A55973)
2013 Chevrolet...
