Anyone with a 72" MMM and a 59" Snowblower on a 3000 series?
   / Anyone with a 72" MMM and a 59" Snowblower on a 3000 series? #1
orlo
Guildhall, VT
JD 2305/JD 4720 cab
Hi:
I have a 3720 and have been using an 84" RFM since last fall. Due to this I haven't used my 72" 7 iron MMM since early last fall. the dealer installed my front hitch/lift and front PTO for my 59" snowblower. I took the blower and arms off, etc. early last spring. I went to mount my MMM today (I wanted to bag and use the cyclone rake) and the first swearing event was realizing It seemed I had to remove the Front PTO shaft bearings. 4 about 25mm bolts in a hard to get spot that was probably tightened by a torque wrench. Anyway, I get that off, I do all the other pain in the butt stuff for the MMM and the front hanger seems like it's about 5" back from where it needs to be so I can put the hanger bracket in it? I don't have the front pto/hitch manual (Dealer never gave it to me). I looked at my MMM install/parts list and the hanger bracket does not look like what's on there now.
Does anyone have a 3020 series with a MMM and a snowblower? Am I just cracking up or is there a bracket or adapter I'm missing?
Thanks for any help anyone can provide.
   / Anyone with a 72" MMM and a 59" Snowblower on a 3000 series? #2
I have a 3720 cab tractor with 72" 7 Iron mmm and 59" front mount snow blower. I use it primarily for mowing 6 acres of lawn in summer and clearing snow from approx 2000 ft driveway in winter. I have never removed the front attach mechanism for the front hitch. For the summer, I remove only the hitch itself (3 or 4 pins if I recall) along with blower and drive shaft -- no wrenching involved.
I'll take a look at mine tomorrow (tractor is in barn) and see if I can be of any help. Will also check to see if I have the manual for hitch and drive shaft.
Thanks. I'm wondering if there is another plate that mounts on the hooks on the plates for the snow blower or something.
Actually, is there any chance you can take a picture of your front hanger bracket? If so that would be great.
Thanks,
   / Anyone with a 72" MMM and a 59" Snowblower on a 3000 series? #5
Thanks,
I have the manuals for Front Hitch, Front PTO Kit, and Mid-Mount Mower which may be helpful. The english portion of the Front Hitch manual is only 11 pages -- could try to scan & email to you or make hardcopy and send to you. Let me know what you'd like.
Will also take a picture.
I think a picture would be great. That would let me know if I have a different hanger bracket or the same one you have.
Thanks,
   / Anyone with a 72" MMM and a 59" Snowblower on a 3000 series? #7
I've got the pictures but have never uploaded on this site. Can you point me to the procedure for uploading/posting the pictures. Alternative is to email them if you give me your email address. My email address is sunnyside1203@windstream.net.
   / Anyone with a 72" MMM and a 59" Snowblower on a 3000 series? #8
sunnyside360, when you post a full reply or post a unique message, all you have to do is look down below the text entry box, and you will see a button that says "Manage Attachments" click on that , and you will see what to do at that point. You find the pic/graphic on your PC, upload it and the close the pop-up window, and then if you are finished with your text message you click on "Submit" or "Submit Reply" This does not work on quick replies.
   / Anyone with a 72" MMM and a 59" Snowblower on a 3000 series? #9
Nuru, many thanks for pix posting info. I'll give it a try.
   / Anyone with a 72" MMM and a 59" Snowblower on a 3000 series? #10
My first try at posting pictures, thanks to Nuru for info.
Since my tractor has front fenders, I have 4 or 5 pictures at different angles because fenders prevented good shots.
2015 Ford Transit 250 Cargo Van (A53422)
2015 Ford Transit...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
