Case-IH FARMALL 95 Reviews
5.00 star(s)
3yalbrecht
FARMALL 95 Case-IH
Farmall 95 FWD
Model Year: 2012
So far I am very pleased with the value, power, and features of this tractor. Currently this is the largest tractor that I operate, and it has ample power for the equipment I use: grinder mixer / hammermill, 12' tandem krause disc, 3 bottom 16" moldboard plow in heavy land, 9' Krause offset plowing disc. The only drawback is the small fuel tank which will only last about 6 hrs. at heavy work. Lastly, I had to do a fair bit of cast iron weighting, both front and back to overcome the "4WD power hop" during heavy draft loads (discing).
Pros: Value, power, 0% financing, features.
Cons: Small fuel capacity.
Photo Uploads:
5.00 star(s)
Anonymous Poster
FARMALL 95 Case-IH
My Farmall 95
Model Year: 2008
So I bought this tractor as a primary tractor. I needed a tractor that I could use for my custom hay operation as well as light tillage and planting. I used a 9 foot haybine and a discbine as well as raked and baled with a traditional side pull baler and an inline 16 x 18. While haying I experienced the hand throttle break, but it was under warranty. My dealer had a replacement in the tractor before I went to the field the next day. After ballasting the tractor I was able to pull 4-16 bottoms, and prepared my seedbed then planted winter wheat. No problems. I miss the bar axle from larger models, but overall it worked great.
Pros: Great on fuel and comfortable to operate for long days and nights!
Cons: I wish it had a speedometer.
