For Flat Yards Only
Model Year: 2014
I found the comfort okay if you were on flat ground, but because you sit rather high on the seat, on hills you get the feeling you could turn over. The steering pushed and did not turn the tractor even at slow speeds. The steering locked up several times as I tried to make rather sharp turns, as it is it has a rather large turning radius.
Pros: Good price
Cons: Not assembled and adjusted properly
