Belarus 7111
Model Year: 1986
This monster V12 has tremendous torque. Unbelievable pulling power. Make fun of Russian tractors all you like, but I am laughing all the way to the bank. A high horsepower 4wd for $4,500, and easy on fuel. I don't have the equipment to make this beast work so I can run a gear higher and run at 1500 rpm. Normal operating rpm is 1900 so my tractor isn't even breathing heavy. Have had no problems other than the A/C (American made). One interesting feature is the pre-lube. An electric motor spins an oil pump which brings the engine oil pressure up to 60 psi before you even turn the engine over. You can keep your expensive machines, I have no loan payments and still get the same work done at the end of the day.
Pros: Cheap to buy. Cheap to run.
Cons: Parts may be harder to find if you need them.
Photo Uploads:
