TYM 293-1 Reviews
3.00 star(s)
dbelling
293-1 TYM
TYM 293
Model Year: 2010
Jury still out on this tractor. Have had problems with hydraulic leak and now overheating problems. I am currently going though warranty situation with dealer. I like the tractor when it is running good.
Pros: Good engine plenty of power.
Cons: Overheating, hydraulic leak,
3.00 star(s)
plato56
293-1 TYM
TYM T293 HST
Model Year: 2009
Overall I'm satisfied with the performance of my TYM T293 compact tractor. I've had it in for two service visits since purchase. At 55 hrs. the 4x4 shifter had to be adjusted because it wasn't shifting properly and the right side rear axle seal had to be replaced. At 106 hrs. the right side engine mount had to be replaced and the seat was replaced because the seat was being damaged by contact from the right side hydraulic/throttle control console.
Pros: Mitsubishi 29 HP engine.
Cons: Concerns about getting replacement parts in the future.
Photo Uploads:
5.00 star(s)
Doug Orlando
293-1 TYM
My TYM 293 HST with FEL
Model Year: 2011
My tractor is a gem! Awesome power for such a small piece of equipment. The fiberglass body could have been restricted to the rear fenders and hood, but I added steel reinforcement to the rear fenders, and left floor area as well as a step attached to the lower frame and overcame those small issues. The rope needs drain holes drilled at the base where it attaches to the main frame as they will fill with condensation and rain (when left down) and corrode. A simple 5/16" hole drilled at the very bottom of each side rope will do the trick (be sure to spray a Rustoleum paint to ensure that doesn't corrode too). The powder coating on all the steel would last better if the metal edges were rounded before coating. The sharp edges make for very thin covering and the first place the powder coat peels at recommend repair by painting with a Rustoleum brand paint. Their bright red matches pretty good. The belt recoiler for the seat belt needs to be relocated to the rear mounting bolt. You'll have to swap bolt as one is longer than the other. To allow the belt to angle properly and to operate smoothly. I added lights to my ropes to provide light after dark as the tractor lights are very ineffective with the FEL attached. A couple 55 watt halogens mounted mid way up the top half of the rope will "light you up deluxe"! I also added a backup light to that circuit to be sure to help with the rear moves. There's a hole for easy mount between the rope right behind the seat. I also installed a backing beeper. To pacify my bride most of all. A simple micro switch, small spring and 2" of light chain attached to the reverse pedal arm did the trick. I have added chain hooks to my bucket and box blade to assist with log drags. I just finished building a set of hook and grab bucket forks for the front. In fact I have to go finish welding them up as my new grapple front attachment is due to arrive day after tomorrow and I'll need the forks to get it off the truck! In short, (I know, "too late for that now!") I'm very pleased with my TYM293HST tractor. Go getchya one---you'll like it! Be blessed, by Jesus...and look up. our redemption draws very near! Doug
Pros: Size, flexibility and power to size, plus the 3cyl mitz engine!
Cons: Fiberglass floor and fenders without reinforcement (though easily overcome).
5.00 star(s)
Tom Bacon
293-1 TYM
My TYM Tractor
Model Year: 2010
I have no experience with tractors in order to compare the TYM with other models however this tractor and backhoe was easy to learn to operate and has performed flawless in every job I have undertaken. Compared to other models which claim to be made in USA and really are 99% outsourced, the quality/price is unbeatable. Should I ever need another tractor, I would definitely put this at the top of my list.
Pros: Ease of operation, low maintaniance.
Cons: Few dealers at this time.
Photo Uploads:
