Depending on your original hydraulic hookup, it might or might not work - independent of pump capability (and yes, it will do the job, just real slow). My BH connection is a two-port PB connection, last in line, so no PB output and only a return to sump. The 3pt (normally last in line) is disconnected and the BH connected using QCs. In that case, you could connect a SINGLE valve (which I think a splitter is) to the BH connection and it will work, but you will have no 3pt. If you need the hitch to hold up the splitter, and the BH connection disables the 3pt, you'll have to do some replumbing before your splitter can be operated.
