Transaxle Fluid
   / Transaxle Fluid #11
I hate it when a manufacturer doesn't spec oils then expects you to pay a ridiculous price for their "proprietary fluid." I bought a new Harley-Davidson bagger I was told by the dealer to only use the Harley-Davidson brand oils. The way they described it it was a special oil that you could only get from them that came from a special oil well that pumped crude formed from badass T-Rex dinosaurs and added 20hp
Your initial problem was you bought an over priced bike with caveman technology and then succumbed to some salesman's song about HD oil.
Can I sell you the Brooklyn Bridge?
   / Transaxle Fluid #12
The reason why I use it is because it's one of the fluids that BCS lists as acceptable. And the only one that was available nearby.
Candidly, I don't care if you urinate in the transaxle, it's yours and the sole responsibility for it's longevity or failure lies solely with you and you alone. One thing I never 'cheap out' on is lubricants. You always (or in most cases) get what you pay for.
   / Transaxle Fluid #13
Anything but the cheap Traveller fluid will work. That Traveller stuff is bad ju-ju.
You may do well to put your biases aside. Accredited labs such as Blackstone has analyzed new and used Travelers Products many times and declared them to be a good oil.
I am in no way implying that they are a Kubota SUDT oil, but if they meet spec for your piece of equipment, it will do no harm in using it.
   / Transaxle Fluid #14
Go to the Hydrogear site and look up BDU 10 it will give you the correct info
Tracter
   / Transaxle Fluid #15
I've been using 15-40 motor oil in my 2544 transaxle for about 5 years now and it's working good. (Just to save money from having to use the expensive CC oil.) I use Traveller Universal Tractor Hydraulic/Transmission fluid in my BCS two wheel tractor. I'm thinking this would be good for the CC 2544 transaxle also.
Any thoughts?
I have a 1986 model 1610 that i ran Traveller hy-tran for many years
It has a Peerless transaxle with a Eaton pump
Last spring i pulled the transaxle out and split it open to replace a snapped axle (broke at wheel)
The gears and differential looked like new inside
I refilled with Traveller again
   / Transaxle Fluid #16
Just did a Zero Force SZ model Cub Cadet's both side transmission HydroGear fluid and filter change. The dealership had some expensive stuff, but the owner said using their Kioti brand 20-50W would work just as well and a lot cheaper. I had a heck of time with this job and will post in another thread.
   / Transaxle Fluid #17
When I had a peerless 2000 transaxle, I was shocked by the $16 per quart Cub Cadet price on it. So I ran Mopar ATF+4 synthetic instead at $4 per qt. No issues with the hydro after that either.
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55302)
NEW 2025 Load...
Mini Excavator Bucket (A53316)
Mini Excavator...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
