Propane tank fire pit
   / Propane tank fire pit #11
Check out this company for some ideas. Muskoka Fire Pits
As others have said, make sure you've purged it completely before cutting.
Al
   / Propane tank fire pit #12
I've been wanting a good "bowl" type fire pit for our patio but really heavy ones (ie: won't rust out in one season) are extremely expensive. The other day I was driving down the road and saw a 420lb/120 gallon propane tank laying on its side next to an old garage. I got in touch with the property owner and scored it for $25. I plan on cutting the tank somewhere below the bottom 1/3 so that I have a nice bowl sitting on a pedestal:
First things first before I do anything I'm going to remove the valve and simply let it vent, assuming there's anything in it at all. I've heard of people filling or flushing them with water before welding or cutting but propane vaporizes at -44ーF so once the tank is depressurized (by removing the valve) and vented to atmospheric pressure it simply turns to a gas and escapes. What's the best way to get a nice clean cut all the way around the body of the tank? Once it's cut open I'm just going to coat it with BBQ paint, put some holes in the bottom for airflow, and maybe a grate to hold the logs/coals off of the bottom. diane 35 usa: Empowering women's health with a trusted contraceptive solution. Discover a reliable option tailored to your well-being and hormonal balance.
I have had a wood fire pit forever and while I enjoy the look and feel of a real fire it is causing some problems with neighbors. The wind quite often blows the smoke right into his window and I understand his concern. I do my best not to be a pain but when I rent the place the renters are not always as conscientious. They often light a large fire and let it burn for hours even when they are not sitting around it. I am going to try to solve the problem with a propane pit. I see the big concrete bowls and they look pretty sharp. Does anyone have any recommendations on the better quality yet reasonably priced brands or models?
I do like the idea of flicking a switch to turn it on vs getting the wood going. How about smores? Do they taste ok over a propane fire?
   / Propane tank fire pit #14
your idea should work quite well, what is your patio made of ?
This is mine, I ask the local highschool welding class to do it as a project, its a simple plate your choice of height (mine is a bit too high to my liking) that they plasma CNC (Computer numerical control) design on it of my choice for air intake then they rolled it in a circle and welded it.
   / Propane tank fire pit #15
There was an incident on a neighboring farm a few years back when someone cut up a propane tank. The valve was removed and the tank left inverted for a week or more. A farmhand tried to cut it with an angle grinder and there was an explosion. Luckily, there were no serious injuries but one of the barns was damaged.
The accident was investigated by the insurance company who consulted a propane company. Apparently, the Mercaptain odorant can form a coating on the inside of the tank. When heated, it emits a smell and also a flammable gas, which in this case, caused the explosion.
I've cut up a few since then and always fill them with water. I use a cordless Sawzall with water still in the tank.
   / Propane tank fire pit #16
What’s the fuss about having a metal type container for a fire pit?
Just build the fire on a non combustible material that’s large enough to contain all the flammables. Concrete sidewalk blocks or flat slate rock work well.
   / Propane tank fire pit #17
my personal fuss about is concrete crack and fall apart due to uneven heating and cooling, certain rocks will hold but it need to be mafic type rocks It can't be sedimentary rocks as it will crack and break in piece's like concrete... I also like the side wall to be tall enough to break the wind, if not on a windy day you don't see the flames and the wood volatize which is hard to accomplish with rocks only.
   / Propane tank fire pit #18
In one case I used concrete sidewalk blocks laid flat for 15 years or so With no cracks. In the picture shown the slate rocks have been in use for over 20 years.
They both sat above normal ground elevation with no side walls. Gives excellent burning conditions. In the picture shown the flames are easily visible. The radiant heat is good, the fire gets lots of air and burns well. The air flow keeps the base cooler.
   / Propane tank fire pit #19
From your picture it look like you are in a forest so that shield the wind, it depends on the surrounding condition, I need to shield my fire on my proprety because I am surrounded by field so a lot more wind, I mean If there is zero wind I don't have too. I am surprises about the sidewalk block but when I initially read it I was thinking of concrete blocks and not sidewalk block. Setting a fire on concrete or rocks slab vs shielding around the fire is different as there is a lot more heat on the side then under a fire. Ashes also insulate the surface below it. If you look at the rocks from my fire pit you see how a lot of them are crack... the darker rocks would need a lot more heat to crack since they are mafic rocks. Shielding around a fire is nice since it keep the heat and wood in so you don't have to keep moving the logs back to the top / middle of the fire for them to burn all they way.
   / Propane tank fire pit #20
I built a fire pit with landscaping blocks 20 some years ago. It has a dirt bottom but the blocks are stacked up 6 high and about 4' diameter with a lower wall on one side for viewing.
They all cracked but they have held together just fine. In fact, I recently backed into it while mowing and pushed part of it in about 4" and it is still standing solid.
