Need help deciding
/ Need help deciding #21
Having a grapple almost reduces getting on and off the tractor to (a) get on the tractor to run it and (b) get off when you're done. The weight of the grapple will eat into your loader lift capacity. Also, good to have more loader capacity than you expect to use because your future needs may be more than you presently anticipate. I bought a L2501 thinking I was only going to clear out some small saplings. A year later, I find myself cutting some mature trees into sections in order to be able to handle them. Having to do extra chainsaw work doesn't sound like a good idea when you say you are having knee and lower back issues. You've limited your choices between Kioti models, but I'm wondering why you aren't at least considering a Branson 2515H which has pretty impressive loader specs for about $20,900 or so.
/ Need help deciding #22
I was definitely glad to get a CK3510 WITH the DPF on the exhaust myself. No residual stink and smoke cloud in my unheated garage when starting up, even when it's really cold. When driving forward under load, I can definitely still smell that I am driving a diesel powered machine, so it's nice to know that most of the particulates have been captured. Not certain as I have not directly compared to a 2610, but I presume that makes the engine/exhaust noise a bit lower as well. My 3510 only regens about every ~50 hours, only takes 15 minutes or so. Sometimes I continue working right through it, other times I take a break and let it do it's thing.
Plus the 35 HP is nice for driving uphill in high range, pretty sure a 2610 (or new 2620) cannot do that. And yes, you can turn up the fuel, but then you void warranty right away, emit more particulates like Jeff mentioned, and probably still don't quite get to 35 HP.
/ Need help deciding #23
You've received a lot of good advice here already, but I'll add one more piece, gained from experience. The best advice I was ever given with regard to tractor/implement purchases and it has served me very, very well over the last 50 years:
Figure out which one you really think you need, then find a way to buy at least the next size up.
I have been sorry for NOT following this advice a couple of times, but I have never regretted following it after those 2 times. I had a Kubota M9000 for 17 years before selling it with the farm at retirement. I thought I couldn't afford it when I purchased it. I found out quickly I couldn't afford to have NOT to purchased it. Never had a single problem with it that I didn't cause myself in those 17 years. The same applies to truck purchases and many other things. Sometimes you might not be able to swing the next larger model, but if you can, you will never regret it.
The second best piece of advice I've received, from the same source:
You can justify anything if you want it bad enough.
Both pieces of advice came from a very wise uncle, who took care of his equipment as well as he took care of his own body. He turned 91 in February and sometimes I think he's in better shape than I am at 69. I could write a small book based on the incredibly good advice he's give me over all those years.
Good luck, and I hope you enjoy your new toy.
/ Need help deciding #24
Kioti is now owned by TYM as is Branson and Bobcat I would go with the 35 HP and for what you are going to do get the standard shift stay away from the HST good luck 🤞
/ Need help deciding #25
/ Need help deciding #26
My limited experience has taught me that with tractors, HP is really only applicable on the size of implement you're able to run with your PTO. Every tractor I've ever seen has been able to produce enough torque to break traction in any reasonable gear regardless of how its weighted.
My 1983 2wd Ford 1710 with its worn out 770B loader, wheel weights, and weighted tires runs around 4000 lbs. It will drag 2 or 3 16" logs that are 16' long with no problems. I'm only dragging them across level ground. I normally skid them in either 2nd range 3rd gear, or 3rd range 1st gear (12spd geared transmission). I'd estimate that I'm moving around 4 or 5mph. Having said all of that, my F350 (4wd, crew cab, long bed) skids logs out to my trailer a LOT faster than a tractor will so long as the ground isn't too soft.
If you're trying to pull out hung tree, even a 35hp tractor is going to struggle. I've managed to yank them out with my tractor (very hard on the tractor). It's been easier to yank them out with the truck. Best way for me has been to put a 12K winch in the trucks rear receiver and use that to pull them out. I could probably put it and a battery on my 3pt, and chain the loader to a tree, and do the same thing, but its easier for me to use my truck since it skids better anyway and the logging roads on the property can get me to the general area.
As far as lifting logs with a grapple is concerned, I think you're going to struggle to lift a 16" x 30' log with a grapple on a 25hp tractor. You might be able to lift it up, but even if your machine weights 4000 lbs, you're not going to have much traction.
All of this to say, get the heaviest tractor you can with the most 3pt lift capacity and the most loader capacity. If you still have money left in the budget, then buy more HP. :)
/ Need help deciding #28
KIOTI CK2520 HST
Engine​
Engine Model3H-TH4A
Engine Gross Power34.9 hp (26 kW)
Rated Speed2,600 rpm
No. of Cylinders3
Fuel TypeDiesel
AspirationNatural
Displacement111.4 cu. in. (1,826 cc)
Fuel Tank Capacity9 gal. (34 L)
Transmission​
Transmission TypeHST Transmission
Main GearManual
No. of Travel Speeds - Forward / ReverseInfinite, 3 Range
Min. Travel Speed of Forward w/ Ag @ Engine rated speed0 mph (0 km/h)
Max. Travel Speed of Forward w/ Ag @ Engine rated speed14.88 mph (23.91 km/h)
Power Take-Off (PTO)​
PTO Type TransLive
PTO Power28.9 hp (21.6 kW)
Rear PTO Speeds (1st)540 rpm
Mid PTO Speeds2,000 rpm (Optional)
Brakes and Clutch​
BrakesWet Multi Disc
ClutchDry Single Stage
Dimensions w/ AG Tire​
Length w/ 3-point hitch120.87 in. (3,070 mm)
Width54.5 in. (1,385 mm)
Height from Top of ROPS92.91 in. (2,360 mm)
Wheelbase65.7 in. (1,670 mm)
Ground Clearance13.39 in. (340 mm)
Front Tread Ag Tires - Min48.22 in (1,225 mm)
Rear Tread Ag Tires - Min47.04 in. (1,210 mm)
Min. Turning Radius w/ Brake107.48 in. (2,730 mm)
Hydraulics​
Total Pump Flow11.73 gpm (44.4 L/min)
3-Point Hitch​
Standard CategoryCategory 1
Lift Capacity, 24" aft of hitch1,631 lbs. (740 kg)
Control TypePosition
Weight​
Weight w/ Ag Tires w/ ROPS2,734 lbs. (1,240 kg)
HP looks odd/high
/ Need help deciding #30
As far as I can find out, Daedong is the Owner of the Kioti brand. Not TYM.
TYM does have Brandson
/ Need help deciding #32
Kioti is NOT owned or even a part of TYM.
Kioti builds Bobcat for them currently, but Bobcat will start building their tractors 'in house' within the next couple of years.
/ Need help deciding #34
Moving logs safely and efficently depends on level ground, hill sides, size of logs and mostly common sense.
/ Need help deciding #36
I couldn't decide either so I went with a CK4020SE HST for roughly the same use on 23 acres. I'll be running a brush hog or flail mower a lot and probably adding a PTO stump grinder and a chipper/shredder so I went with the higher HP to make those tasks easier and faster. I don't expect to do a lot of ground engaging work beyond dragging the driveway with a land plane and possibly tilling a small garden.
/ Need help deciding #37
I keep bouncing between the 2620 and 3520.
I do mostly food plot work, tilling, brush hog, disc and working in the woods dragging logs etc. so grapple setup for sure.
I just dont know if I can turn up the HP on the 2620 needed to drag out logs (20-30ft 10-16" diameter) or if I should go with the 3520 for dragging power
or if the 2620 would have enough torque to do the job at 25hp.
hi fishbones, my recommendation, buy a different brand! I have owned several tractors by kubota, JD and others. i bought a Kioti Mx4510 HST last fall and it is the biggest PITA ever! From fan blade and radiator issues that were not covered by warrantly after only a half hour of use, two hydraulic hose rupture from tight (too short) hoses, again not under warranty, to front loader hydraulic line routing issues that cause damaged lines to just flat not starting and not turning over, too cheap tires with three plugs (only 80 hours) the a dealer that does not stock parts and has to order everything delaying repairs for weeks, nor does dealer have a service truck requiring expensive towing trips to dealer, to proprietary diagnosis codes and lack of shop manuals! worst tractor ever! Avoid Kioti, at least the Post Falls Idaho dealer!
/ Need help deciding #38
I use to own a Cub Cadet 7275hst that had 27hp. I had no problem dragging out trees that size with it.
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2014 VOLVO L45G WHEEL LOADER (A60429)
2014 VOLVO L45G...
2014 FREIGHTLINER CASCADIA 125 SLP (A59905)
2014 FREIGHTLINER...
