Mahindra 8560 AC Not Cooling
   / Mahindra 8560 AC Not Cooling #1
kneedeep
Veteran Member
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
well enough.
It does cool and blows cold air with thermostat wide open. I realize it is nasty hot and try to keep tractor in shade or under shed. With all the glass, it is a hard box to cool off and maintain.
What is the procedure to service/maintain a Mahindra AC? Does it need a shot of Freon? Do coils need cleaning?
I am not a AC guy, so any advice to keep the system operating at peak performance is appreciated!
Thanks In Advance!!
Rod
   / Mahindra 8560 AC Not Cooling #2
Radiator, compressor & cab filters need to be keep as clean as possible. No refrigerant should be added to system without monitoring both high & low pressure with gauges. Have you consider tinting your tractors windows????
