That's correct, a diesel can't run rich unless the air filter or intake is restricted, or a turbo failed on a turbocharged engine. Either way, it would cause lots of black smoke. The fuel injection system controls how much fuel it gets, and a common rail injection system with fuel delivery and pressure controlled electronically is more precise than the old mechanical injection systems which could deliver too much fuel. The quality of the fuel is very critical as others have said, and the only fuel additive we use is winter anti-gel in no more than the recommended quantities because it's an absolute necessity here, or it will gel up even with blended fuel in winter temps where I live. Fuel with even a couple % biodiesel blended in is guaranteed to cause problems and most engine manufacturers forbid it. Red dye in off road diesel has been a controversy for a long time that has never really been solved, so it's anyone's guess. No engine manufacturers have any restrictions on it. And it's important to use engine oil that meets CJ4 or CK4 specification to prevent contamination and prolong the life of the DPF. The regen is controlled by both time and soot load in the DPF. If it doesn't need to do a regen based on soot load measured by sensors on the DPF, it will do one at 50 hours automatically. Doesn't hurt to do a manual parked regen once in awhile either.
