MTGreen
Platinum Member
- Joined
- Oct 12, 2022
- Messages
- 990
- Location
- Montana, USA
- Tractor
- Deere 5220, Ford 1720, Deere Progator 2030
The 2210 was only produced from 2003-2006 because of the pto case failure as mentioned above. My dealer had trouble selling them because of the failure reputation. Excellent for mid mount mowing. The 2305 was the replacement. It came out in late 2005. It had a much thicker and stronger case. it's production run lasted till 2010. Then the one series came out. The 2305 was a much better machine. I would avoid the 2210. Just my 2 cents...
My understanding was the PTO case failures were caused by too long PTO driveshafts lifting to full 3pt height with the Cat 1 limited hitch setup which would break the aluminum case/rear cover castings.
The aluminum transaxle housing LVA802797 and rear cover LVA802798 are the same part numbers for the 2210 and the 2305.
Maybe someone else has some better info.
There is a "DTAC SOLUTION 70105" from Deere on the issue but it's dealer only access -they can print it out for you
I sold my 2210 some years back
