SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,164
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Hi. I have several Kubotas - none particularly modern - but all working fine until just recently. Then the ~ 1990's vintage L2900 I have had for 10 yrs had a circlip come loose inside that made it so that the PTO could not be disengaged. It is a known problem on this model. Kubota has an upgraded part and the dealer has spit the tractor put it in and fixed it. In the process they caused another problem which will severely hamper the tractors utility and they dont seem to be able to correct it.
The GST transmission no longer behaves correctly. - Im guessing this from symptoms ... but, when shifting it appears the auto hydraulic clutching and gear change still happens promptly as it should, but the clutch release to resume drive in the next gear is now badly delayed. The delay is so great that the tractor is liable to coast to a halt with every shift. The shop knows it is hydraulic related and happened there but doesnt seem to know how to trouble shoot the shift valving and get it back right. Worse, they have little faith in Kubota Technical Reps due to prior experience. Even worse, that might be warranted.?
Im sorta stuck here. I believe the senior mechanic is pretty good but not well enough experienced in this GST system. Does anybody here have some deep experience I could pass on to help resolve this issue?
Thanks!
Thanks!
