5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,994
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Only going to get worse, not better and you know who to thank for that. Just bought a SSQA attachment for an LA 364 loader (that I will install for a good friend) as well as a skeleton SSQA plate for his bucket and it was 750 bucks from Kubota. 2 years ago it was 500 for both and with items like that, I prefer not to buy aftermarket (though ATI makes one as well and I have both the ATI version as well as the OEM version on my units).Buying cheap knock off mystery parts isn't the solution to inflation.
Today you have the choice between quality OEM parts or import parts of questionable quality. I know which way I go, you may be different but be apprised that the cheap import parts may not last.
I will say on Kubota tie rod ends, the OEM parts won't come greaseable whereas the aftermarket parts will probably come with grease fittings installed. I've drilled and tapped the OEM ends in the past to allow them to be greased. Not into sealed for life fittings on tractors at all and never have been. Life can be short or long depending.......
if you think Kubota parts have went up, stop by a local green dealer and price their offerings if you want sticker shock.
