I was having a similar issue with my 2007 BX24. It would run gerat for a while and then bog down as if it was out of fuel. I replaced both fuel filters, the fuel pump and the fuel injectors. I thought that would fix it. I was wrong!
I removed the fuel tank (PIA) and poured the fuel through a filter to see if there was crud in it. Some kind of label came out. I don't know where it came from, or how it got into my fuel tank. I reinstalled the fuel tank and gave it a try. Worked good for a few hours while bush hogging 5 acres.
A few days later it started giving me problems again.
I pumped out all of the fuel again. Filled the tank with water and noticed that nothing came out of the fuel hose. I blew compressed air into the fuel line to clear it until water started flowing out. Then vacuumed the water out of the tank. I repeated the process three or four times. After blowing air into the tank over night to dry it, I added fuel and tried again.
Still acting up!
It ran fine at idle, I could rev it up and operate the 3 point hitch as well as the loader. When I touched the HST controls, either forward or reverse, it would die. I jiggled the OPC timer and it worked for a while. I figured that the OPC timer probably got some moisture inside it. A few days later It got so bad that I almost had to tow the tractor to my shop!
I ordered a new OPC timer along with new fuel, air, hydraulic and oil filters.
A few days ago I changed the hydraulic fluid and filter, engine oil and filter, air filter and the #1 fuel filter (before the pump). I decided to wait on the OPC timer to see how the tractor acted.
So far it seems to be working fine. I may have spent $120 on an OPC timer that I didn't need. I'll just keep it in my Kubota parts box until needed.
