K3 Engine Compatibility
   / K3 Engine Compatibility #1
Glassonion
Durham, NC
International 254
Hi all,
I have an International 254, which I believe is basically identical to an MTE2000D, but I think the Mitsubishi used a different engine (K3F vs K3E for the International).
I had a guy look into the engine on mine and one cylinder is badly scored, which is causing a lot of smoke and blowby and keeping it from running decently. I'm looking around for rebuild kits/parts, but they're pretty scarce. I'd also consider swapping the engine for a used one, but replacements seem to be somewhat rare as well.
Does anyone know if any of the other K3 series (D, F, etc) would fit/match up where the K3E is? It might help my search for a replacement if there were a few more potential options.
Thanks!
   / K3 Engine Compatibility #3
Also, you might try a Case-IH dealer. The K3E was also used in the 255, made 1986-1990; the Cub Cadet 7192/3/4/5 made 1995-1997. Welcome to TBN!
   / K3 Engine Compatibility #4
I had the K3D engine in my Mitsu MTE1800FD rebuilt last winter. Poor starting and Low compression on 2 cylinders. I believe the mechanic ordered a kit from Southern-Global in Miss. Had the local machine shop create sleeves for it. Still the last hard part was getting the seals that fit between the end mains and the block. They were very late getting here. Total bill with r & r the front loader and r & r the engine was $4600 +. Starts nearly as good as my RTV-900 now.
Bryce
Wow - That's not nothing :) Glad to hear it worked out well, though.
Hopefully if I do the R&R myself the engine assembly and machining won't be too terribly spendy.
   / K3 Engine Compatibility #6
I have had good success with engine parts from NCW Tractor Parts, LLC I've bought a larger hydraulic pump, new crank and rod bearings, rings and all seals and gaskets from them for my K3F.
   / K3 Engine Compatibility #7
Hi all,
Thanks!
I have K3e valves intake and exhaust will sell for 50 plus shipping i had to get valves for k3d
45fmj
   / K3 Engine Compatibility #8
I am going to have rebuilt k3e is anyone interested complete overhaul
45fmj 6189442756
   / K3 Engine Compatibility #9
Hi all,
Thanks!
I have a rebuilt k3e for sale
45fmj
   / K3 Engine Compatibility #10
Hi all,
Thanks!
k3d should fit
45fmj
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A44391)
2016 Hino 195h...
Volvo SD-100D Single Drum Vibratory Dirt Compactor (A44571)
Volvo SD-100D...
2007 John Deere 9570 STS Combine  Premium Cab  FarmTRAX Yield & Moisture  1,846 Sep Hours (A46877)
2007 John Deere...
2018 Wacker Neuson RTLX-SC3 Trench Compactor (A44391)
2018 Wacker Neuson...
JET Band Saw (A44571)
2025 8ft Office Shipping Container (A44571)
2025 8ft Office...
