Lineman North Florida
Veteran Member
- Joined
- May 12, 2008
- Messages
- 2,091
- Location
- LaCrosse Florida
- Tractor
- Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
Like the thread title says I was harrowing up a field to plant some sudan and noticed tractor wasn't pulling the harrow as easily as it normally does so it continued to get worse and I xarried it to the barn and my first thought was the filter/screen in the fuel tank, as I just serviced this tractor 30 hrs ago which included a new primary fuel filter, so I drained the tank and the fuel looked really clean as in almost no trash and virtually zero algae, pulled the screen/filter and it had very minimal blockage so I felt like that wasn't going to be the problem, and it wasn't. Tractor will rev up but when you put it under the least bit of load even pulling itself in high gear it just bogs. I did notice it will puff a little white smoke along and along, so what do you think? injector? maybe injector pump? maybe sucking air somewhere? I am open for opinions. Thanks. Charlie.
