Iseki ts 1610GLF clutch housing
   / Iseki ts 1610GLF clutch housing #1
Jeek
Iseki ts1610GLF
I have a Iseki ts 1610GLF(the 4wd variant) that had a severely cracked clutch housing. It was repaired but today the welds started cracking and I need a new(un-damaged) one. If anyone has one or knows of one it would be very appreciated!
Thanks in advance!
Info from the parts manual:
Ref No. o30-1-1
Parts Code: 1421-134-0010-1(printed number) or 1421-134-0011-0(someone crossed out the printed number in the book and wrote this one in its place)
   / Iseki ts 1610GLF clutch housing #3
I have parted out a TS1610f. I'll have to check if it has the correct clutch housing. The were 2 styles for the TS1610f. Some had a creeper gear in them.
Excellent! According to my parts manual, there are just the 2wd - GL and 4WD - GLF versions but your knowledge is probably more accurate. Mine does have a High/Low gear selector located at the front of the case, I'm assuming this is the crawler you're referring to.
Continuing a better way to contact me is my email: Bmcsutton1@gmail.com
   / Iseki ts 1610GLF clutch housing #5
Yes The GLF models have the creep.
Okay, did you get a chance to check the parts unit you've got? does it have the creeper
   / Iseki ts 1610GLF clutch housing #7
I've parted out 3 of them, but guess I sold 2 of them. I know I had one with the creep, but the one I have left doesn't have it.
That's unfortunate. Is the one you have left still a 4wd? or just 2wd?
   / Iseki ts 1610GLF clutch housing #9
2wd
