OP
2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 7,402
I searched to see if you had posted any more information on these upgrades, but didn't find any. I'm still curious what engine you used and if you actually see any improvement in the power available to run a brush cutter while also going uphill? Or does the increase in HP not matter so much if the pumps are still the same?The wheel motors are around $700 each. However, keep in mind, you would need to modify the wheel mount weldment slightly. The larger displacement wheel motors are about ½ inch longer. While you could use a spacer to make up the difference, I elected to cut out a ½ inch thick plate and weld it to the mount. This involved cutting a large hole and a bolt circle in the plate.
My modified 425 uses a 35-horsepower motor and larger wheel motors than used on the 1430. But still, it’s no “powerhouse”.
I'm guessing the 1430 and 1445 will be more stable due to the increased width and weight?
