Artisan
Veteran Member
What I do not know about electricity will fill volumns and volumns.
Frankly, I am absolutely horrible at it. I just don't savvy...sad it is.
Are there any 12Volt guys here w/ a BX25 interested in getting more
electrical power out of their BX25 (or) that can advise me?
I have been thinking about it for a while and the first obstickle I
foresee that needs a solution is the physical mounting of the alternator itself.
Getting into bracketry changes can be done but I hope for a bolt-in plugNplay
solution. I MAY BE ON TO SOMETHING.
Putting 2 and 2 together I fell upon a 60AMP Alternator (the BX25 is 40 AMP)
that has the exact same front case as the BX25. Many other components are
the same. I think the rear of the case is different, if it is a different plug there
is another solution needed which may be as easy as a pigtail, just make a
M4800SU-F to BX25 PigTail Adaptor perhaps?
So the other tractor, and there may be more solutions but my brain can
only multitask and process so much info at a time, the other tractor is
the M4800SU-F. Here is a side x side exploded view analysis of the component
parts for their alternators. You see the front half of the case is the same!
What else needs to be considered in such an upgrade? I imagine it might
be wise to switch to the battery as recommended for the M4800SU-F which
I believe will not pose any fabrication needs, I think it will slip right in, although
I need to verify.
I think there are voltage regulators to be considered, but are the regulators
not internally mounted within these units?
What else must one consider? Will wire size be a huge issue?
And I guess if this were a swap in plugNplay unit what is the, perhaps,
Mitubishi or other? Mfg's part number for the same unit because
Kubota is INSANELY expensive for their Alternators! The prices
are NUTZ!
TIA!
I need to verify.
are NUTZ!
TIA!
